2nd Fuel Filter - before or after factory filter
Submitted: Monday, May 12, 2014 at 20:14
Top End Az
I wish to install a secondary
fuel filter on my current model Dmax. I have been reading through various suppliers. There seem to be various opinions on whether to have it installed before or after the factory unit.
I always thought you'd put it in before the factory unit but there are a number of options for fittment aft the factory filter.
I guess at the end of the day it's good insurance either way. But any pros or cons against going with one way or the other?
In addition have any Dmax owners fitted one, if so any feedback?
Thanks in advance
Reply By: Offsider - Monday, May 12, 2014 at 20:23
Reply By: Member - ironJosh - Monday, May 12, 2014 at 20:23
If you have a
water sensor light on the original
fuel filter, its a good Idea to put one in after that. Reason being, when the light comes on it's not too late (as is sometimes the case). A filter with a visible bowl is a great idea. Too!
Josh
532370
Reply By: CSeaJay - Monday, May 12, 2014 at 20:26
Before (upstream) from the OE filter.
That way when you change, there are not contaminates going downstream without a filter to catch
Better to install for the same reason
And, for one reason or another my dealer will honour the warranty if upstream but not if downstream.
All filters are really better as pre-filters IMO
CJ
532371
Follow Up By: Member - Phil G (SA) - Monday, May 12, 2014 at 21:16
I agree 100%.
IMO the most important (and usually ignored) thing is to prevent contamination during filter changes. Something as simple as taking off the downstream
fuel hose during a filter change can introduce dirt that has not been thru a filter.
815627
Follow Up By: Top End Az - Monday, May 12, 2014 at 21:31
Yes, that is a really good point I hadn't considered.
815630
Reply By: Member - Rosco from way back - Monday, May 12, 2014 at 20:37
Another vote for primary rather than secondary.
532372
Reply By: Ross M - Monday, May 12, 2014 at 21:00
It all depends on the micron size you are going to use.
If fitted between the OE filter and the engine you have to be very "clean" with the installation. "Meticulously Clean" otherwise you will introduce "thing's" into the direct line to the High Pressure pump. Most people do not know the meaning of clean.
A filter fitted there will render the OE restriction sensor inoperative if the new one restricts.
So, unless it too has a wired in alarm for restriction, then the OE will not detect the new filter has blocked. It shouldn't of course.
They can work
well there but if restriction occurs you will only know by performance loss.
Filters fitted before the OE filter retain the operational/sensing of restriction if either/both filters restrict. Many are fitted with a larger micron than OE so there is a gradual removal of contaminants. The New filter should have/be a dewatering filter which has a really good go at eliminating emulsified
water held within the
fuel molecules.
Just a bowl or a
Water Watch filter can catch and/or alert the
water is there, but the emulsified
water can go through and usually has unless there is a filter which is designed/featured to catch it.
Nothing is perfect, but a suitably selected filter which dewaters, finely filters, has a visible bowl and perhaps
water detection wired also to the vehicle is a good start.
A suitable flow rate is essential to have proper performance without premature restriction occurring. Most 3 litre engines require 120L/H flow rate or more, so some contaminant catch can happen without having to change the filter every short drive. Some are too small in flow rate.
A 2011 Dmax flows about 35L/H and so a x 3 factor seems suitable for the filter size.
532375
Reply By: 08crd - Monday, May 12, 2014 at 21:17
I installed
mine before the manufacturers, reason being, last time I picked up a
tank of bad
fuel was during floods.
So removing/draining etc is carried out before the main filter during bad weather.
My pre filter has a clear
water trap/
water alarm and an aquabloc filter of 30microns.
532379
Reply By: Kanga1 - Tuesday, May 13, 2014 at 08:49
Top End, we have an additional filter fitted to our 2013 D-Max.
Click here there are some helpful comments at the bottom which cover some specific details. Cheers, Kanga.
532394
Follow Up By: Top End Az - Tuesday, May 13, 2014 at 14:45
Hi Kanga.
Thanks for that. It was this article and one from DieselCare that had me asking the question initially.
815666
