Wednesday, May 14, 2014 at 10:30
Nomadic Navara
Earlier Navaras used to break the towbar OFF the chassis until they changed the mounting system.
Tom 2
An 18ft van correctly loaded and the ute the same should be ok.
I would make sure you have rear springs which cater for the load and try to avoid airbags. That will then retain some or all of the ride height and give you a
suspension which isn't closed up and likely to bottom.
Bottoming will bend a chassis quite easily as the van load hits.
The idea is to have compliant
suspension with sufficient upward travel, which controls the dynamic load forces.
The OE shocks will most likely be not much good at the control of the van forces. Something not noticed on a smooth road but in rough the OE shocks will show their deficiencies.
Compliance and absorbing of forces is the name of the game.
The D40 seems to bend about 300mm rearwards of the front spring hanger, close to the shocker upper mount point.
It is there the forces are concentrated and IF too much it will bend like most others.
Another very obvious thing is, many towbars used with vans have too much of the tow neck sticking out the rear of the actual towbar
That increases the load on the chassis, springs, axle and lifts the front more, than it should. So short as possible behind the axle for the ball position is best.
I have redrilled quite a few so the ball load isn't being MAGNIFIED into the chassis. Some of the tow system sold are simply madness in the way they don't consider all the forces.
They are certified of course, but that is no good after the crash.
I have recently been involved with D40, bent from new, NOT LOAD RELATED at all, and it appears to have slight depressions on the inner chassis face close to the shocker point and the chassis tails are uneven in their relative heights.
I agree with Peter D, if a WDH is used sensibly and the towbar forces are correctly spread by it's attachments, then it applies the load in the opposite direction to the normal bending, rear downward forces.
It all makes the chassis work harder than normal though.
There is a dualcab D40 near me and it's tray is very down at the back, even the dog would slide off. Just a load has caused
the bend because to much weight applied behind the axle and the middle goes up.
815711
