2 quick questions.
Submitted: Sunday, May 18, 2014 at 22:13
flyingfrenchman
Hi all,
Having just come back from a weekend away I have come up with the following couple of questions.
Are small rocks stuck in the tread of the tyres an issue and need to be removed?
Is there a problem with putting diesel in a petrol jerry can and using it?
Cheers for your thoughts.
Reply By: Whirlwinder - Sunday, May 18, 2014 at 22:23
1) No
2) No
532721
Reply By: Member - mike g2 - Sunday, May 18, 2014 at 23:46
you'll be busy for quite a few yrs removing small stones! -not a problem.
petrol will osmose into metal of can over time to a small degree, is a problem when people cut open
fuel cans/drums with torch or grinder and bang! bottom line is the remnant amount of petrol is tiny and its a very doubtful problem to diesel engine.
MG.
532728
Reply By: flyingfrenchman - Monday, May 19, 2014 at 00:38
Thanks for the replies guys, as expected not an issue but thought there may have been something I hadn't thought of. I'll just be removing the stones that make the annoying ticking while driving on the hard top. Cheers
532730
Reply By: Ross M - Monday, May 19, 2014 at 10:23
Only problem with stones is if the SAME one stays there for a long period it can be driven further and further into the tyre case.
If the same tick is there for a long period then I would flick that one out, but generally they remove themselves during braking, cornering or general tread squirm and are no problem.
Mostly the ones which stay there are TEK screws.
532747
Follow Up By: Member - Scott M (NSW) - Monday, May 19, 2014 at 11:36
Yeah
Ross, those flat head metal stones are the worse...
816054
Follow Up By: SDG - Monday, May 19, 2014 at 17:38
But leave them in until at a tyre repair joint. I find they seal reasonably
There are exceptions though.
816070
