Coment on a MR Funnel
Submitted: Wednesday, May 21, 2014 at 12:35
Member - reggy 2 (VIC)
In my wisdom I decided to try my Mr Funnel at
the servo before heading out on our trip to
the desert.
After stopping the
hand pump at the bowser I waited for
fuel to go out and waited and waited to discover that about 4mm does not drain out oop's what am I going to do with the 4mm in the bottom shaking got about 2mm out.
By this time the
shop attendant come out to check what I was doing after a bit of explaining and dumping the last 1-2mm in the garden stones I was on my way.
The long and the short of it is don't us the funnel at
the servo .
Reply By: Member - Trouper (NSW) - Wednesday, May 21, 2014 at 12:42
Will you have the same problem when decantering
fuel from a 'jerrycan'
532888
Follow Up By: Mick O - Wednesday, May 21, 2014 at 13:25
Reggy, the 15mm 'sump' at the bottom of the funnel is to catch all those nasties and particulates. Much rather be throwing out the 30mls of diesel and rubbish than having it in the
tank. It's great for catching
water, rust particles from jerrycans, bits of plastic or rubber from plastic cans, dirt and any other little bits and pieces that can find their way into stored
fuel.
Cheers Mick
816180
Follow Up By: Member - Michael P (QLD) - Wednesday, May 21, 2014 at 17:22
Mick Hi,
Using the Mr funnel at
the servo, does it slow the filling process down much? A couple of
the servo's I use have limited bowsers.
Thanks Mike.
816198
Follow Up By: Mick O - Thursday, May 22, 2014 at 10:57
Mike,
My mate Jaydub had the double outlet funnel and we have found that quite slow. I have the single outlet model and have found that good providing you get the
fuel 'swirling'. Once the vortex effect takes hold, it will pull the
fuel through very quickly. This was not possible with the larger double outlet models.
Cheers Mick
816252
Reply By: bluefella - Wednesday, May 21, 2014 at 18:08
Carry it in a bucket with a sealed lid, it holds the dregs and stops the smell. Empty it when you find somewhere suitable like
servo with a workshop open.
532909
Reply By: Member - John (Vic) - Wednesday, May 21, 2014 at 19:00
What size funnel you using?
532913
Reply By: Rangiephil - Wednesday, May 21, 2014 at 19:12
Hi, I have a dual Mr Funnel and used it for the first time at a
servo at Binnu WA.despite the claims the funnel only drains even reasonably quickly if filled. Right up with diesel and goes slower and slower as the level goes down.
I decided to check only the first 10 liters as it was so slow, and even then
the servo lady asked me what was wrong
I reckon at a busy
servo like Overland,you would be lynched if you tried to check the entire flow.
So I now just make sure to fill at high volume servos and maybe check the first 10 liters into the
tank and then fill the jerries.
My TD5 is not as sensitive as common rail
One thing you cannot control is that unknown to all the blokes filling at Overland , there out the back out of sight was the bulk tanker merrily filling the
tank. I am sure some of the common railers would have had a fit if they knew.
Regards Philip A
PS I heard that 4 cars got a gutful in the last couple of weeks after all the rain in the
Kimberley. It was at one
servo AFAIR at
Karratha or Roeburn.
532914
