deep cycle aux battery
Submitted: Friday, Jun 13, 2014 at 12:25
ThreadID: 108234 Views:3343 Replies:8 FollowUps:5
Does anyone out there know why my 6 month old deep cycle battery wont hold a charge. I can fully charge it. But as I turn my fridge on it drops straight down to around 10volts, I turn the fridge off and jumps back up to 12 volts.
Reply By: Krooznalong - Friday, Jun 13, 2014 at 13:18
A psychic is a person who claims to have an ability to perceive information hidden from the normal senses through extrasensory perception.
I'm one and I perceive that it has dropped a cell.
AnswerID: 534288
Follow Up By: Les PK Ranger - Friday, Jun 13, 2014 at 14:11
Ie. If bought locally, take it back for testing and possible warranty.
If purchased online, more difficult, maybe have tested locally to diagnose fault, then approach online seller with info to claim warranty.
That's the beauty of buying locally when possible.
FollowupID: 817886
Follow Up By: Bigfish - Friday, Jun 13, 2014 at 15:54
WHY?...Because it is stuffed. Take it back....warranty job
FollowupID: 817888
Reply By: HKB Electronics - Friday, Jun 13, 2014 at 16:49
BrendanI4,
What model is your car?
When your measuring the voltage are you measuring it on the battery terminal posts
or the battery terminal clamps?
What brand of battery?
How do you know the battery is fully charged?
How is the battery normally charged?
Leigh
AnswerID: 534293
Reply By: D-Jack - Friday, Jun 13, 2014 at 18:55
I would say it is not charging properly....12v is not enough. Maybe your charger???
AnswerID: 534298
Reply By: Member - kyle46 - Friday, Jun 13, 2014 at 21:16
brand /type. ??size
AnswerID: 534307
Reply By: Nomadic Navara - Saturday, Jun 14, 2014 at 16:13
Brendan, a fully charged battery should be around 12.8 V, not 12 V. I agree with those who say the battery is not being charged. When are you going to answer the questions posed by the others so we can give you some real answers?
AnswerID: 534343
Follow Up By: brendan l4 - Saturday, Jun 14, 2014 at 16:49
I have an 80 series, dual battery set up, 2 acdelco batteries, the aux battery gets charged by a solar charger when we are stationary. It gets a full charge. I check it at the battery post. I also have an in car monitor. When fully charged it is around 12.8 volts with no load, but once a load is connected eg fridge, it drops straight down to 10.5 volts. From there it continues to drop quite rapidly.
FollowupID: 817951
Follow Up By: Nomadic Navara - Saturday, Jun 14, 2014 at 17:14
I take it that your 12.8 V reading was taken 4 - 6 hours after charging and not shortly after the charger was removed (ie so you are not measuring a surface charge.)
FollowupID: 817957
Reply By: Allan M7 - Saturday, Jun 14, 2014 at 16:27
Brendan it can have a lot to do also with how far have you discharged it and how long did you leave it in a low charge state. Deep cycle batteries should not be taken below 50% Soc
Which would equate to about 12.3 to 12.4v so if your battery is reading 12v then it could be as low as 25% soc. As others have said check your charger.
AnswerID: 534345
Reply By: The Bantam - Sunday, Jun 15, 2014 at 16:44
It is not unusual for batteries to have a very short life indeed.....no matter what the brand or type of battery if it is cycled too deep or too often it will die in short order.
Some batteries, a single realy deep cycle can kill them.
AnswerID: 534420
Reply By: Member - Jim B8 - Sunday, Jun 15, 2014 at 19:47
Brendan
You have good quality batteries, good enough. There is always better. And people fall for the trap of buying the latest, greatest batteries, AGM, whatever.
Charge (lack of, mainly, but not only) and heat kills batteries. Run them way low, or cook them with engine heat, and kiss them goodbye. dying in front of your eyes. Deep cycle along with the rest. You say you have solar, but do you park it outside often? What wattage, what controller, PWM or MPPT?
Yes, cells do just die, and yes that's a warranty issue. But have you had similar issues before? I know a lot of people who have had batteries failing for years, and move on each time to a "better" battery each time.
There is a lot of good advice in the replies but one thing that stands out is the question about when you measured the voltage? During charge, or how long afterwards? About 14.1 volt during (the latter stages of) charge, and it drops down to 12.8 if unused, and in good condition, once the charge is removed (say 20 minutes later). But with load connected, it will drop a lot faster. But don't expect to measure the battery voltage when its wired in place, load and the charge system will affect the measurement
All those figures are approximate, because the internal resistance of the battery changes as it takes charge.
Make sure you give the vehicle regular runs. Don't leave on a substantial load such as a fridge unless you need it. Solar doesn't do much in the shed. Buy yourself a small cheap smart charger, say a Ctek 5 amp smartcharger, and wire in the loom that comes with it such that you can quickly plug in the charger when you get home. Its only 2 wires onto the battery.
The smartcharger indicates the state of charge with led's. When you are 100% sure the battery is fully charged for most of its life, then you can consider what battery is best. Low charge will kill the best of them.
But with certainty, your current battery is dead. Yes, it can be that you got a dud, it happens. But only very occasionally. Think back, did you ever run it flat? Real flat? That time out with your mates?
Replace it, and look at charge system vs your usage
Do I sound like a bloke who has spent a lot of money making bad decisions re batteries in the past ha ha?
Good luck
AnswerID: 534433
Follow Up By: brendan l4 - Monday, Jun 16, 2014 at 10:02
Yeah thanks mate. I probably have just ran it flat a couple of times especially on cloudy days. Charging is not an issue on sunny days, I have have a 195w solar panel connected to a mppt charger. I also have a 30m extension cable so I always have it in the sun.
FollowupID: 818093
