Pre Filters
Submitted: Tuesday, Jul 29, 2014 at 02:50
Member - Terry. G (TAS)
Know that its been around a lot but more I read more I get confused with flow rates ect .So I have a 2007 Toyota Work Mate Cruiser obviously with the V8 Motor .
Question is any other members fitted a pre-filter
water separation unit to a V8 Diesel and if so please what has been used and has there been any disadvantage by doing so like loss of power ,lack of
fuel pressure
.I keep hearing //reading about
fuel pump cavitation ,
fuel restriction and the list goes on .I would prefer a pre-filter
water separation unit rather than just a
water separation unit if possible
Thank you all and hope some one can help with this
Terry
Reply By: Green Rv - Tuesday, Jul 29, 2014 at 07:42
Hi terry
have a look at this unit.
http://www.terraintamer.com/he/4wd-products/filters/item/207-fuel-manager
i have used this before and had no problems came as a kit with a 30 micron filter
Adam
536762
Follow Up By: Ozrover - Tuesday, Jul 29, 2014 at 08:59
I fitted one of these to my 2012 78 series dual cab, pretty much as soon as I got it, the 30 micron filter takes care of all of the heavier particles, as
well as any
water in the system.
The Toyota filter at 4 microns takes care of all of the lighter particles & is also a backup for
water.
Comparing
mine to the older work Ute that only had the standard filter, the work ute filter bowl always had a layer of silt in it as
well as corrosion due to
water sitting in the bottom.
In my ute the standard filter bowl is still clean & shiny, & I only ever get a tiny bit of silt in it when I change filters.
820982
Follow Up By: The Landy - Tuesday, Jul 29, 2014 at 09:44
I have the same unit mounted pre-Toyota filter and echo the comments from Jeff.
I have just returned from a 10,000 kilometre trip across the Anne Beadell amongst other
places with
fuel from a variety of sources. When I changed the filters the other day there was only small particles in the Toyota bowl, but it was fairly clean overall.
In contrast, another vehicle travelling with us, the same engine without the pre-filter had a lot more sentiment in it. Now that isn’t necessarily a perfect comparison given it was on the vehicle for slightly longer and
fuel from other sources, but made me happy I had the 30 micron pre-filter installed.
I haven’t noticed any power changes or other issues.
And noting, in need, I also use the Mr Funnel filter at the point of adding
fuel, depending on the source. This is probably one of the best ways to ensure no crap enters the
fuel tank in the first instance.
Good luck…
820986
Follow Up By: Green Rv - Tuesday, Jul 29, 2014 at 10:22
hi guys
some cars had problems with
fuel supply if run through a fine micron filter
this is only because they use a low pressure pump (like crd patrol) and struggles to get through 2 filters. as with cavitating i dont know where that one come from
Adam
820992
Reply By: Richard and jem - Tuesday, Jul 29, 2014 at 07:47
Gday Terry
I've got a 200 series ttd and use a secondary
fuel filter 5 micron with no problems only thing having it as a secondary is you need to make sure the area is clean from dust when you replace the filter I brought it through Diesel care came with all the parts needed to fit including bracket worthwhile giving them a call as they were very helpful on the phone with the best set up.
If you can log on to lcool heaps of imfo on their about a 2nd
fuel filter.
Dicko
536763
Follow Up By: Member - Jim - Tuesday, Jul 29, 2014 at 17:30
My 200 series is set up the same as Dicko with no problems.
Jim
821006
Reply By: Mick O - Tuesday, Jul 29, 2014 at 08:14
Terry, there has been many discussions about this topic as a search of the
forum will reveal. Threads 100706 and 100622 are good examples. I am using the Terrain tamer
fuel manager filter system which is fitted after the factory filter on my 2009, 79 series V8 ute. I have had no problems with
fuel pump cavitation, lack of power or loss of
fuel pressure nor have I heard these stories on the
forum. My vehicle is also chipped and tuned to provide optimal power conditions when towing.
I have heard a lot of stories about contaminated
fuel and the failure of the OEM filter to prevent
water getting into the motor. I got a funnel full of crap from a
fuel drum at
Well 23 a few years ago which would have been all but fatal to my engine had it not been for my Mr Funnel. That prompted the move to the extra filter.
Mine is aft of the OEM filter to let the OEM do its job as intended. The
fuel manager is then the backstop.
Just ensure that you have adequate hose diameter at fitment and anywhere the pipe might pinch or bend when fitting into the tight Toyota engine bay, use the spring-wire hose maintainers.
Regards,
Mick
536766
Follow Up By: The Landy - Tuesday, Jul 29, 2014 at 09:50
Hi Mick
Thanks for the “heads-up” on the Mr Funnel some time back; it got a good workout on the recent trip and not surprisingly, captured some crap from getting into the tanks.
I have the same Terrain Tamer filter (also your suggestion!) but mounted pre-OEM given it is 30 micron. My thinking was also it was better having the OEM as feeding to the engine in case anything ever goes wrong.
Is there a reason to have it the other way? Oddly, it was originally installed the other way around.
Cheers, Baz
820989
Reply By: Member - Markthemilko (WA) - Tuesday, Jul 29, 2014 at 23:27
Hi Terry,
I have a 2007 V8 VDJ79 Workmate ute.
I fitted a Stanadyne 2 micron with a primer-pump (fits on top of the unit), filter change kit (= flag pops up to indicate needs changing), and a glass bowl for $440 (trade, July 2012). I fitted it behind the main
tank and it is plumbed in so that
fuel flows through this one to the Toyota filter situated between the 2 batteries. No room under the bonnet for the second one. The other day I noticed the motor lacking a bit of power so I checked the flag and it had popped up. I keep records: it had filtered 2014 lts for 15,120 kms (=7.5kms/lt). The filter is easy to change.
Some of that
fuel was bought at
Laverton,
Warburton,
Kiwirrkurra, Carnegie and
Menzies on a recent desert trip (5,000kms).
I cut open the filter - it was black, but there was no sediment in the bowl.
Interestingly, in the service book there is no mention of when to change the
fuel filter! I guess when the dash light illuminates. Though I'll probably never have to change it because of the Stanadyne. I bought it in
Perth from
United Fuel injection (no affiliation).
536829
Reply By: Member - Terry. G (TAS) - Wednesday, Jul 30, 2014 at 01:38
Well gents first up thank you all for your time and information, (Markthemilco) I sent you a pm and thank you for your comments . (DBNO5) Harvey tried to send you a pm to but could not ,but will either catch you down the street or come around very interested in seeing what your set up will be like . have to leave will follow this up thanks terry
536833
Reply By: Member - Terry. G (TAS) - Saturday, Aug 02, 2014 at 23:20
Well gents thank you again I did not leave the discussion after just gaining what info I could from you all.I had to wait on a couple of reply' s.One being from Diesel care ,after asking you all and communicating with them at ( Diesel care), it looks like the Stanadyne
filtering system will be the way I will go .I received prices back for secondary filter kitat $317 .00 plus $25.00 postage to Tassy .The additional
water warning light is $230.00.Not sure yet but assume this is for the FM100 Series - up to 350HP Max
fuel flow (inc. return flow) 300 Litres/hour.At least hope so not sure yet is the
water warning light can be brought separately or not.
Thank you all again gents for both your time and help thanks
Terry
537041
Follow Up By: tonysmc - Sunday, Aug 03, 2014 at 09:44
Yes the warning light can be bought separately, as I bought
mine separately. The light and bracket are quite big, so I cut the light off and soldered on a small LED and a Piezo buzzer as sometimes a light alone may not get noticed for a while. Having the separate buzzer I know that if it ever goes off I know instantly what is happening, rather than the generic buzzer for all the other things.
Tony
821304
