Hand Throttle
Submitted: Monday, Mar 01, 2004 at 22:17
Rosco - Bris.
G'Day one and all
Anyone had any experience with hand throttle set-ups for drive by wire jobs.
About to have a leccie hauler fitted to the beast and based upon my observations I understand it's best to tweak the revs up to 1200 or so rather than at idle to maximise alternator output during the tug.
The Fender has a drive by wire throttle control gizmo ....... hang about .... I believe the Nips are going in that direction also .... great copiers aren't they ... ;-)))
Anyway, back to my question ... anyone set one up or know how to ... other than a block of wood. A tad difficult when there's only a couple of 2mm wires between your go hoofer and the donk.
Fidei defensor
Rosco
Reply By: Kev - (Cairns,QLD) - Monday, Mar 01, 2004 at 22:21
"Nips"
Haven't heard that one for a while.
48808
Follow Up By: Rosco - Bris. - Monday, Mar 01, 2004 at 22:24
You know how it is old chap .... have to try to keep the lads under control ... what.Fidei defensor
Rosco
310621
Follow Up By: Gazza - Monday, Mar 01, 2004 at 22:54
Would anybody care to translate???
The process I intend to follow is as follows:
1) Measure the range of the potentiometer that is activated by the throttle pedal IE 0 to XX Ohms.
2) Cross check that value with a wiring diagram.
3) Obtain a potemtionmeter of the same wattage at about 0 to (XX Divided by 3) which should produce a maximum handthrottle setting of about one third maximum RPM.
4) Fit the "pot" via a switch that isolates the normal accelerator controled pot from the cct.
NB The switch to change from foot to hand throttle should not be used unless the ingnition is off as there is no way to know how a "spike" introduced by the switch may be interpreted by the ECU (probably poorly)
Given your original question I think it likely that you find an auto sparky to do the work but I think that you need to find one who is comfortable with more than fitting new bits, someone who actually understands electronics.
Gazza
310635
Follow Up By: Rosco - Bris. - Tuesday, Mar 02, 2004 at 07:23
Gazza
Thanks mate I thought it may be that complicated .... a block of wood's looking good.
CheersFidei defensor
Rosco
310648
Reply By: Voxson (Adelaide) - Monday, Mar 01, 2004 at 22:29
Speaka Englais????___________________________________
Simpson trip 05/04 then turn left at
Birdsville to
Darwin via
Lawn Hill etc
48810
Reply By: Wayne (NSW) - Monday, Mar 01, 2004 at 22:50
Rosco,
On my first 4WD a 1988 N-ss-n P-th-rf-i--er. It did not have a hand throttle. So with a hand throttle I picked up from the wreckers, I mounted it at the bottom of the dash and connected the cable to the top of the throttle. A little bit of adjustment and I had a working hand throttle.
Might also check out early Defenders before drive by wire and see how they did it.
Wayne
Always Out'N About
48816
Follow Up By: Wayne (NSW) - Monday, Mar 01, 2004 at 23:19
Rosco,
You don't have a lever at the top of the throttle do you? If this is the case the cable would have to be mounted to the floor and attached to the top of the pedal, with the pull or wind knob on the dash.
WayneAlways Out'N About
310639
Reply By: Steve - Monday, Mar 01, 2004 at 23:19
Reckon that.. I M H O ....a lot of the 'members' on this site throttle themselves by pulling their wire ..not sure what revs they need as I am not a member of the Bulldogs and .....
48823
Follow Up By: Willem - Tuesday, Mar 02, 2004 at 13:06
TROLL......Willem
Little Dip Cons
Park S.A.
310674
Reply By: Member - jtb - Tuesday, Mar 02, 2004 at 03:30
how often are u gonna winch , go the brick ,but a bit more advanced ,maybe, and u dont want anything going wrong on the big trips do u ,other wise i would talk to LR CHEERS rather be fishing
48837
Follow Up By: Rosco - Bris. - Tuesday, Mar 02, 2004 at 07:29
Jtb
Your 127 long range
tank. Does it replace the original and if so does it extend any lower ? Thinking along those lines myself but not keen if it hangs too low.
Rosco
310649
Follow Up By: Member - jtb - Wednesday, Mar 03, 2004 at 02:04
hi rosco yes it replaces the original and is obviously larger but clearance is not to bad, cannot think of what standard unit looked like ,my ball hits first anyway been there , the longranger
tank is designed to give u the best entry angles that are possible but i have just found out it is 132ltr ,be sure to change
fuel filter just after installation, fitting prices should come with full
tank of
fuel for testing $$$ then 4-5 weeks later u get to finally put
fuel in it , and are over it when u fill the
tank $$$$ , the auxillary is filled through underneath drivers
seat 80ltr not my cuppa diesel fumes cheers rather be fishing
310798
Reply By: Member - jtb - Tuesday, Mar 02, 2004 at 05:25
where is the little desert
ross ty jtbrather be fishing
48838
Follow Up By: Voxson (Adelaide) - Tuesday, Mar 02, 2004 at 07:53
Just outside of Dimboola / Horsham (vic)___________________________________
Birdsville to
Darwin via
Lawn Hill etc
310652
Reply By: Brian - Tuesday, Mar 02, 2004 at 09:55
Rosco
cut a piece of 2"x1" wood and knotch it at each end.
Then just wedge it up under the dash and to the pedal, simple cheap easy and it worked
well on my old SIII.
Brian
48849
Reply By: Willem - Tuesday, Mar 02, 2004 at 12:32
Rosco,
Tie a piece of light wire(or whatever) to the accelerator. Feed the wire through the firewall through one of the grommets and out through the front of the grille. Now put loop in wire for finger to go through. Pull finger to get any revs you want while you are using the hauler. Too easy.
My old truck has a built in handthrottle. Maybe the Poms can learn something from the Nips...hahahahaha
Willem
Little Dip Cons
Park S.A.
48863
Follow Up By: Rosco - Bris. - Tuesday, Mar 02, 2004 at 14:28
Knew I could rely on you to come up with a pearler ol' mate.
Rosco
310697
Reply By: Member - Bradley- Tuesday, Mar 02, 2004 at 16:16
The idea of the seperate pot for adjusting the voltage signal to the throttle body sounds good, but switch off for change over.. you can get electronic interfaces for the drive by wire systems, like the auscruise system, but cost is about a monkey or so. Block of wood or better yet a custom length of wooden dowell costs less than a beer ..mmmmmmm....beeeeeerrrrrr.
Then again if you have the cool breeze fitted then just switch that on and see what the revs rise to. Just killin time till
easter...............go and play in the dirt, instead of workin in it......
48889
Follow Up By: Rosco - Bris. - Tuesday, Mar 02, 2004 at 17:03
A piece of stick's sounding better all the time Homer.Fidei defensor
Rosco
310718
Reply By: Wayne (NSW) - Tuesday, Mar 02, 2004 at 21:19
Rosco,
When you are winching your self out of a pickle, you would be in the drivers
seat, controlling the vehicle with the remote winch switch coming from the control box across the bonnet and in through the drivers window. A light touch of the throttle with the right foot should elimate the need for a hand throttle.
Winching someone else out and your vehicle anchored, the same procedure will apply. You are safer in your own vehicle when winching than out.
48937
