BT50/Ford Ranger Extension
Submitted: Tuesday, Sep 23, 2014 at 17:21
tuck
Has any member with a 2013/14 Dual cab had there chassis extended by say 600mm to accommodate a steel / alum tray for canopy / slide on camper. What companies have they used? Have they increased
suspension to accommodate any extra weight.
Reply By: DmaxQld - Tuesday, Sep 23, 2014 at 17:54
Honestly think you are asking for trouble if you extend any dual cab by that much. If you are adding a camper as
well, I reckon you would be needing to do a GVM upgrade. Would not recommend airbags in the rear of a dual cab. Lots and lots of horror stories about broken chassis on dual cabs with air bags.
539443
Reply By: tuck - Tuesday, Sep 23, 2014 at 18:18
I know there have been conversions done. Yes I would upgrade shocks and springs and no bags. Heavier items ,
water ,fridge, all in front of rear axle
539446
Reply By: Member - Barry P (VIC) - Tuesday, Sep 23, 2014 at 19:16
have 2014 twin cab
ranger,arb do a 100 kilo upgrade on
suspension,plus cost of engineers report,i have not had this done,watch your gvm weights,my
ranger at the moment weights 2.46 ton,fitted with bullbar rear bar,bash plates ,side rails and steps aluminium tray ,have now put on a slide on camper on 420 ks plus,have not been back to the weigh bridge yet,3.2 tonnes is the gvm max weight,not much to play with,for beer and jacks straps etc,its an 3.2 automatic loves the
fuel in 5th and 4th gear hope this helps barry
539449
Reply By: Robert P - Tuesday, Sep 23, 2014 at 19:44
Hi Tuck,
I think what you are suggesting is a reasonable way to accomodate the extra equipment you wish to carry. As always more knowledge of anticipated weight and overhang is essential (to your engineer) to offer sound advice.
A wheelbase extension with the appropriate chassis extension should give you the overall capacity you require and should be reliable, however I do think you would have a pretty long vehicle that might be a handful in the bush and on
sand dunes, so depending on what you expect there could be other consideratoons.
In such a discussion I think you need to carefully think of the vehicles original design, in this case say medium duty 4wd, and look at what it is you expect, and you really are heading into heavy duty 4wd, so maybe a rethink of the vehicle choice or accomodation is required.
Our experience with dual cab utes (std w.base) was with a camper trailer and we did have one or two chassis issues in heavy 4 wd terrain.
Hope these thoughts are of interst to you.
Rgds,
Rob.
539452
Reply By: Bob Y. - Qld - Tuesday, Sep 23, 2014 at 19:57
Not what you asked Tuck, but we had a 100 series Toyota done by Creative Conversions in Brendale(
Brisbane). Added 500mm and chopped the arse off to make a dual cab.
Came out pretty
well, but did have some dramas initially. Attention to wiring at rear was slapdash, and the dual diesel
tank filler didn't!!! Unless you were prepared to take your time.
No dramas with chassis extension. The tail shaft had an extension added, and a centre bearing fitted. This caused some grief, and we were replacing c/bearings roughly every 12 months. Must say at this point that the vehicle spent 90% of its life on station roads and tracks.
Once you add that half a metre it becomes a different vehicle. Heavier, almost cumbersome and vastly increased turning circle......tend to lose their nimbleness. Probably increased
fuel use too.
If you're going to go ahead with the cut 'n shut, then forget any steel trays........stick to alloy. Beef up rear
suspension and if you fit air bags...........
well, you've had some sensible advice above.
Hope you something sorted, and it gives you good service,
539454
Reply By: tuck - Tuesday, Sep 23, 2014 at 20:38
Thanks BobY
Actually agree with most of your details. We had a Patrol stretched,did 250 k without any problems. Only sold during to age and ks .Did most deserts,cape ,
Kimberley's.The new Mazda,Rangers have stronger chassis ,weight would come in on maximum but would be increased margins by better suspensionjust wondering lf anyone out there has done a NT or
Ranger
539459
Reply By: whackywombat - Tuesday, Sep 23, 2014 at 21:09
There,s an extended chassis PX
ranger forsale on gumtree.com.au I'm sure the seller could answer a lot of your questions
539462
Reply By: The Bantam - Wednesday, Sep 24, 2014 at 21:40
Its not my vehicle but a good friend...he went out a baught a brand new BT50 dual cab and a slide on camper to match.
This guy is an engineer and thaught he had done the math.
Well....not long after he was off getting the chassis stretched and an extra axle put under the back of it.
These vehicles suffer the same issues that ALL the dual cab utes suffer and that is there is almost no tray infront of the rear
wheels and anything you put in the tray has this unfavorable leverage that puts a lot of weight on the rear axle and a lot of stress on the rear chassis.
Personally I loathe and detest dual cab utes mostly because they load up so very unfavorably.
You may think dual cabs are wonderfull.....but you need to understand that there are some very hard/ expensive issues to deal with due to the unfavorable way they load up.
539497
Follow Up By: AlbyNSW - Thursday, Sep 25, 2014 at 05:47
I saw a similar setup last month in Tib. It had a chassis extention gullying canopy with two spare
wheels at the headboard end and it was towing a 20 something foot van
I was cringing watching it just driving over the driveway crossover of
the servo. You could see how much the chassis was flexing by the way the canopy was twisting and moving
Didn't look pretty.
824143
Reply By: The Landy - Thursday, Sep 25, 2014 at 07:16
No problem with our Toyota 790 Series Dual, made for the job. But worth noting discussions on GVM always need to take account of both front and rear axle weight limitations.
Cheers, Baz - The Landy
539505
Reply By: wombat100 - Thursday, Sep 25, 2014 at 14:08
I had my BT50 done by 'Specialised Vehicles' (check out their website) near Orangeville NSW. Great job- GVM increase etc. 4 pages of engineers specs.
However- NOT cheap !!
539508
Reply By: Batt's - Friday, Sep 26, 2014 at 11:52
I talked to the RTA earlier this yr they gave me a list of six companies that you can get GVM upgraded springs from legally I can't find the list but ARB, Lovells springs are on it just ring the RTA. I would talk to one of the
suspension suppliers about your requirements before you start the extension because you will definitely need a decent GVM upgrade get a bit heavier than what you think and don't be afraid of heavy springs like most people are because if you get the correct shocks to match you'll get a good ride. Don't forget to add peoples weight on as
well plus extras you will add on later down the line. Use an alloy tray to keep the weight down.
539546
Reply By: tuck - Friday, Sep 26, 2014 at 12:52
Thanks to all the Replies. Have taken on board a lot of suggestions .
539548
