Battery Charger
Submitted: Saturday, Oct 18, 2014 at 23:25
humpback
When people are staying in caravan parks and running off 240 volt power do you turn your battery charger off or leave it on.
Humpback
Reply By: MAVERICK(WA) - Saturday, Oct 18, 2014 at 23:48
a very rare occurrence going to a cara
park but when I do I use the 240 pwr to charge the 2nd battery through a charger. It is supposed to be smart enough to shut itself down when not needed. rgds
540521
Reply By: Member - Brian - Saturday, Oct 18, 2014 at 23:49
I think you would leave it on till your battery was fully charged then turn it off
540522
Reply By: Dennis Ellery - Sunday, Oct 19, 2014 at 02:30
If you have a modern caravan it should have a combination power supply/battery charger – not an ordinary battery charger.
Whilst connected to 250v your 12 volt lights will run off the 12v power supply circuit and not the battery.
The battery charging circuit will, once the battery is fully charged, switch to its maintenance program and its 250 volt input should be left on.
540527
Reply By: Member - Alan H (QLD) - Sunday, Oct 19, 2014 at 07:48
In my van everything is 12V except the aircon. The batteries are charged by solar or by a charger if on 240V (usually solar is enough - don't have any electrical connection to tow vehicle)
If we connect to 240V all it does is operate the battery charger to keep batteries charged and allows operation of 240V power points without the inverter. The fridge etc continue to operate on 12V
As mentioned I would leave your charger on to take of batteries. I would have thought that when connected to 240V is the only time your charger will operate anyway.
540528
Reply By: kevmac....(WA) - Sunday, Oct 19, 2014 at 19:54
My smart charger stays plugged in and switched on at 240v outlet, so that when I either use a carvan
park's power or rare occassion have to run gennie it will always charge the van battery. Even if it is only to "float "the battery.
540562
Follow Up By: kevmac....(WA) - Sunday, Oct 19, 2014 at 19:55
....and of course when van parked up at home.
826462
Reply By: Garry S3 - Tuesday, Oct 21, 2014 at 21:50
I wouldn't worry too much. however, if it does come across that the battery is full I will switch it off.
540664
Reply By: Nomadic Navara - Wednesday, Oct 22, 2014 at 15:48
It depends upon the charger. If it is a quality multi-stage model then they are designed to be left on. When they are first switched on they go through the charge cycle and when they are finished the cycle they reduce their output to a float or maintenance level. The float charge is just sufficient to keep the battery from self discharging.
It its a cheap one it could be just a taper charger. Those types will over charge the battery if left switched on and boil the battery dry.
540684
