How can I attach a none slip rubber mat to a tub liner
Submitted: Sunday, Nov 23, 2014 at 20:19
Member - Boo Boo (NSW)
G'day all
I have a hard plastic tub liner in my Colorado. Unfortunately
the tub liner is as slipper as grease.
I have bought a none slip mat and would like to secure it to
the tub liner.
Should I use self tapers or silicone, or is there another way?
Your thoughts would be appreciated.
Reply By: Member - John - Sunday, Nov 23, 2014 at 20:30
Maybe try Sikaflex and the primer that can be used with it........... I am sure that others will come up with other possibilities.
542109
Reply By: TomH - Sunday, Nov 23, 2014 at 20:56
If its a heavy one and is cut to shape it will probably just sit there.
Putting screws through it will just tear holes in it if it moves.
Did to the one I put on top of the drawers in my Cruiser
542113
Reply By: HKB Electronics - Sunday, Nov 23, 2014 at 21:27
Plain old silicon, non acid cure preferably will just about stick anything to anything. Stopping
water laying under the mat might be an issue though, if the crud gets trapped between the mat and the liner it may get smelly etc.
542118
Reply By: Peter_n_Margaret - Sunday, Nov 23, 2014 at 21:51
Tub liners are made from Polyethylene.
It is a bit like gluing something to a candle.
Essentially, nothing will stick to this stuff with any life certainty. It is specifically excluded by Sikaflex.
I would consider hot air welding some reinforcement patches to
the tub and then using mechanical fasteners to them.
OKA196 Motorhome
542120
Reply By: Ron N - Sunday, Nov 23, 2014 at 22:38
Boob Boo - A good quality Silastic will probably suffice for all intents and purposes - but if you want a stronger bond, try 3M's Scotch-Weld PR100.
You will need some 3M AC77 primer for the polyethylene to get a proper bond.
This stuff is a cyanoacrylate product and it bonds on contact, so ensure your alignment is correct before positioning.
This adhesive also requires a close tolerance fit to work properly (maximum gap .015mm), whereas Silastic will tolerate large and uneven gaps.
3M Instant Adhesives
Cheers, Ron.
542121
Follow Up By: Ron N - Sunday, Nov 23, 2014 at 22:40
P.S. - Have you thought about spraying
the tub liner with a heavy thickness, non-slip paint coating? A marine product could fill the bill nicely.
828353
Reply By: Shaker - Sunday, Nov 23, 2014 at 23:50
I just read your other thread, all that "red paste" is probably grinding away between your tub liner &
the tub, if it was me I would throw
the tub liner away, I have seen some very badly rusted tubs under liners"
542124
Reply By: AlbyNSW - Monday, Nov 24, 2014 at 05:39
Boo Boo I had the same issue on a couple of my utes and I just used a normal rubber ute mat cut in to the floor shape and they are heavy enough to sit down under their own weight and don't move around
I bought my Falcon one from Clark Rubber and on my Hilux used a genuine rubber mat, just had to trim it a bit smaller to allow for the poly liner
542126
Reply By: member - mazcan - Tuesday, Nov 25, 2014 at 16:18
hi boo-boo
ive own 3 dual-cabs since 1986 and ive never bothered with tub liners
I have just only ever gone into clark rubber and bought a length of multi-rib rubber matting 1200 wide and length to suit
its tuff and lasts for years doesn't need adhesive and stops things sliding around
take out and wash when need be
also use a piece in 6x4 trailer at times
tub liners get dirt and moister under it and it will eventually cause rust that I have seen as proof and some one else also mentioned
the multi rib matt also stops road noise and drumming into your cab particularly if there is a fibre cab attached to the
well-body the cost will be minor compared to a tub liner
my two bobs worth from personel experience
542182
Follow Up By: Member - Boo Boo (NSW) - Tuesday, Nov 25, 2014 at 20:36
Thanks for the replies people
I forgot to mention that the mat is in 2 pieces and based on the info supplied I will leave it as is so that I can take it out and clean it, or I will join the 2pieces together and still leave it loose.
828430
Reply By: Slow one - Wednesday, Nov 26, 2014 at 20:36
Boo Boo,
my experience with tub liners is very negative. As stated before
water gets under the liner by either sweating or ingress and sits. The result is severe rusting.
I have a liner in my tub but I have a canopy and roller draws. I cut the liner out on the bottom under the draws and coated the sides of
the tub with soft seal before reinstalling the modified liner. Another thing is at the front of your tub you may find 2 holes high up on
the tub each side. I suggest you seal these with sikaflex.
In your situation I would remove the liner. Soft seal the front and sides. Cut the liner with a jigsaw so that it only protects those side areas and smooth the cut edges with a cheap deburring tool and reinstall.
Then I would place a removable mat on the bottom of
the tub so you can check and dry it out if necessary.
542212
