charging deep cycle battery's from a inverter via a smart charger to
Submitted: Monday, Dec 29, 2014 at 08:37
BOXHD
Hello ...I have a friend that asked me to asked anyone on here if they would no if it is or can deep cycle battery's can be charged by 240 volt projecta smart charger which is plugged into a 1000w inverter in which is hooked via the battery's....
hope this makes sense...cheers boxhd
Reply By: Racey - Monday, Dec 29, 2014 at 08:50
If it's the same battery, the answer is NO.
543480
Follow Up By: Jackolux - Monday, Dec 29, 2014 at 09:32
Wouldn't the charge just go round n round and the batt would never go flat ( just kiddin )
830425
Reply By: Member Andys Adventures - Monday, Dec 29, 2014 at 08:50
Just to get an idea what your doing.
The battery that the inverter is connected to is different to the one you want charged, or is it the same battery.
543481
Follow Up By: BOXHD - Monday, Dec 29, 2014 at 08:55
hello...andys... he told me its from the same 2 battery's and tells me that when he tried it yesterday for a Cpl mins that it was showing that the smart charger was putting in 20 amps but wasn't sure wht the inverter would be dragging out in amps ..I said mb that would be just going in cycles ...
830421
Follow Up By: Member Andys Adventures - Monday, Dec 29, 2014 at 09:07
No he will go backwards. The inverter and charger will use more than what's put back in.
Cheers Andy
830423
Follow Up By: BOXHD - Monday, Dec 29, 2014 at 09:10
Ok thanks Andy's for that ..that's wht I through it would be doing
830424
Follow Up By: Kazza055 - Monday, Dec 29, 2014 at 09:42
Sounds like a
mobius loop
830426
Follow Up By: oldtrack123 - Monday, Dec 29, 2014 at 12:27
HI Box
You have it right going in circles with ever decreasing battery capacity
In fact, every full cycle would loose around 10<15% of battery capacity due to energy lost in the inverter, charger & batteries
PeterQ
830434
Follow Up By: Member Andys Adventures - Monday, Dec 29, 2014 at 12:37
This will give you some idea how you will lose power.
When you turn on the inverter it will draw power say 2amps (example only) them if the charger is producing 20 amps it would draw more than the 20 amps, and the charger only puts back 20 amps and hope the battery will accept it, leaves you short by at least 2 amps, but would be more. The tec sav people can give you accurate figures.
If it did work I would have no need for solar panels or generator. Turn
my home to 12 volt and never have a power bill again.
830436
Follow Up By: Nomadic Navara - Monday, Dec 29, 2014 at 15:28
Quote "Sounds like a mobius loop"
Not so much a mobius loop as perpetual motion.
830439
Reply By: pop2jocem - Monday, Dec 29, 2014 at 21:40
I checked the calender. It ain't 1st April.
So could I ask. Is your friend part of The Chaser team?
Failing that, and assuming for a moment the question is on the up an up.
What exactly is the end game here? What is the object of all this?
Pop
543498
