Carrying 2 stroke fuel
Submitted: Wednesday, Jan 14, 2015 at 09:53
AlbyNSW
I like to travel light and frugally and don't see the point in using up valuable space and weight carrying more
fuel than needed.
I am looking for a storage container to carry
fuel for my chainsaw and are looking for a suitable container in the 500ml to 2 litre sizing. 1 litre would probable be ideal for me.
Does anyone have any suggestions? There are plenty of 4 and 5 litre ones available which I already have so looking smaller
thanks in advance.
Reply By: Member Andys Adventures - Wednesday, Jan 14, 2015 at 10:12
Try an old oil bottle, and keep in cool place.
544221
Reply By: Member - John - Wednesday, Jan 14, 2015 at 10:13
ebay, I have some similar to these for fire lighter, haven't looked at all of them, should be a lot cheaper than this one. Hate that, can't add pics for some reason. Follow the link.......
http://www.ebay.com.au/itm/Fuel-Bottle-1-Litre-/321591925708?#ht_1874wt_1363
544222
Follow Up By: AlbyNSW - Wednesday, Jan 14, 2015 at 15:38
Thanks I had a mate who used to use this type for his Shellite stove, Have been to 3
camping stores looking for them but no luck.
Funny I have even done a search on Ebay for small
fuel containers with no luck but you managed to find them
831348
Reply By: Member -Pinko (NSW) - Wednesday, Jan 14, 2015 at 10:27
AlbyNSW
My thoughts on large containers are the same as yours.
The one litre inflammable products in the hardware store IE. Diggers brand turps,kero,metho etc with the large safety cap.
It happens that those bottles fit neatly inside 70mm pvc stormwater pipe.
I made a 16mm plywood plug for the bottom and another for the top with a hole to let the bottle cap come through. The length of tube is long enough to protect the bottle cap and the ply plug pushes down on the shoulder of the bottle to keep it tight.
The ply plugs are fastened from the outside through the pvc with brass nails or screws.
I keep shellite, 2 stroke and unleaded in three separate bottles. Been doing this for three years.
544223
Follow Up By: AlbyNSW - Wednesday, Jan 14, 2015 at 15:40
Thanks, that sounds like a good system you have going there.
831349
Reply By: Tuco - Wednesday, Jan 14, 2015 at 10:32
Get one of these ...
1 litre fuel bottle
I have been using a Castrol Super 2 Stroke oil bottle for premix since 1975 when I had a 2 Stroke OSSA motorcycle. Castrol have changed the design and style of bottle many times in that time. Fortunately the opaque one (with side level marks) isn't affected by petrol. Many plastics don't like petrol.
Cheaper aluminium drink bottles can be sourced from the likes of Reject
Shop and some
camp shops.
544224
Follow Up By: AlbyNSW - Wednesday, Jan 14, 2015 at 16:21
Thanks for that, I like that one in the link you posted as
well
831357
Reply By: Member - Tony (ACT) - Wednesday, Jan 14, 2015 at 11:09
I use two 500 ml plastic oil bottles one for
fuel and one for bar oil. They fit in a cut off 5 lt oil container along with spare chains.
Lasted 6 months on a trip last year, used for cutting fire wood.
This along with 10 lt of gennie
fuel, all fit in the gennie slideout locker.
544226
Reply By: Member - Mark (Tamworth NSW) - Wednesday, Jan 14, 2015 at 14:12
Alby
When I am carrying my
fuel stove in my backpack on long bushwalks I use specialised 500mL-1L
fuel bottles for carrying metho, petrol & shellite,. They are one of the safest containers you can get and very robust. They have a small tap at the top that allows you to accurately dribble out small volumes if required.
But they are expensive, $25-30 each for the Trangia brand. You'll find them in any good
camping shop that sells back pack
fuel stoves.
544237
Follow Up By: AlbyNSW - Wednesday, Jan 14, 2015 at 16:08
Thanks Mark
That was the style I initially had in mind
I tried a BCF and Anaconda and they did not have them at the time. A few have posted links to them on line also so will chase them up
831353
Reply By: Peter_n_Margaret - Wednesday, Jan 14, 2015 at 15:29
I used to carry a chain saw and
fuel and oil and a spare chain and sharpening stuff.
Now I leave it home.
Sometimes I carry a 240V sabre saw and run it from the inverter.
Cuts anything.
544245
Follow Up By: AlbyNSW - Wednesday, Jan 14, 2015 at 16:24
Peter I don't bother either unless I am going to heavily timbered areas.
I do own two sabre saws and an electric chainsaw for home use but you would be seriously under gunned with them in
places like the High Country
831358
Reply By: Rod W - Wednesday, Jan 14, 2015 at 15:37
You seem to contradict youself in that you like to travel light and frugally and don't see the point in using up valuable space and then in the next sentence you're carrying a chainsaw that requires fuel.
So get rid of the chainsaw which eliminates the need for fuel thus you not using vauable space and become more lighter and frugal. Why do you need a chainsaw in any case. I bet you also carry an axe?
544247
Follow Up By: AlbyNSW - Wednesday, Jan 14, 2015 at 16:18
Rod you obviously have never been to
places like the
Vic high country otherwise you wouldn't have made such a remark.
There is a difference between travelling light and travelling unprepared.
I don't take my chainsaw when I go to central Australia or the deserts but it is wise to have one in heavily timbered areas.
I was in the high country again just two weeks ago and was glad I was not the one who had to remove some of the trees that had been across the tracks in the days prior.
I hope this makes sense to you.
I don't carry an axe by the way
831354
Follow Up By: Frank P (NSW) - Wednesday, Jan 14, 2015 at 16:38
Absolutely agree, Alby.
The standing dead trees that were killed by fires in the last 10 years or so are now starting to fall regularly. I think it is now unwise to go into fire-affected alpine areas (and that is much of it) without a chainsaw.
Just a couple of months ago I went up to
Geehi dam through fire-affected country. Had a clear run, but thought to myself "I wonder if my luck will be as good on the way back?"
It wasn't.
In the couple of hours I spent poking around the dam and surrounds, a dead tree had fallen across the only access track and I had to clear it.
There was no wind - these things just give up and fall at any time.
For the same reason you also need to be very careful about choosing a
bush campsite. "It'll be right for one night" is very likely to be wrong. (Nat
Park campsites have generally been made safe.)
831360
Follow Up By: Rod W - Wednesday, Jan 14, 2015 at 21:58
Yep that makes sense but an axe takes up less space.
831393
Follow Up By: AlbyNSW - Wednesday, Jan 14, 2015 at 22:14
Rod unless you can swing an axe like the guys at the Royal
Easter Show you would be setting up
camp next to some of these trees whilst you worked your way through them
There is a lot of timber that comes down up there and some massive ones at that
831394
Reply By: gbc - Wednesday, Jan 14, 2015 at 16:03
Google up sigg
fuel bottles. You won't get better or safer for small volumes of
fuel.
544250
Reply By: Ron N - Wednesday, Jan 14, 2015 at 16:41
Alby, don't make the mistake of buying a narrow-neck fuel bottle.
These things are often designed to normally connect to a stove via a coupler.
A narrow neck bottle is a PIA to refill.
Acquire a wide mouth bottle, you can refill them easier and see the amount of fuel in them.
SOTO make a 1000ml wide mouth fuel bottle, but I'm not sure how easy they are to acquire.
Cheers, Ron.
544255
