Sunday, Mar 07, 2004 at 23:59
As I said before I have not worked on a GU tanks but I think this is how it works.
The
fuel tanks have a float in the
tank it self. It is attached to the sending unit and when
fuel is added to the
tank the float will rise up with the level of the
fuel. This will cause the sending unit box (and I am not sure how to explain how it works but that is not important at this stage), to send a signal to the
fuel gauge on the dash to show a reading,empty to full. The low
fuel warning light also works off this float system. When the float has moved close to its lowest point,
fuel tank almost empty, the warning light will come on. This is how I think it should work. If the warning light does not come on then the float might need adjusting.
Once the float has reached a low level the transverse pump will turn off so as not to run dry.
Again removing the sending units and trying them out of the
tank through there full swing of the float with the ignition lights on.
I hope this answers your question, I know it is pretty general but there are not many ways a sending unit works.
Wayne
311286
