Monday, Feb 02, 2015 at 14:43
I don't mean to be pedantic steamfire01, but a Surf is actually a Hilux. Next time you get a chance, check out the badges on the back of a Surf above the number plate light and you'll see it is actually badged a Hilux Surf from the Toyota factory :-P I'm not disputing your later points, just
clearing up this small point that a Surf IS a Hilux, just not an Aust factory delivered Hilux.
Names aside, I suspect you're simply trying to make the point that the Hilux Surf doesn't have the same components of the Aust factory delivered Hilux, that I agree with.
Most people agree the Aust delivered Hilux is a bit more reliable and parts availability is better than a
grey import, which is definitely something rayni M needs to consider in 4WDs of this age and mileage.
rayni M, the '96 model you've linked to is not as common as the '93 model. With parts supply already less common on Surfs compared to an Aussie Hilux, the '96 model parts supply may be slightly harder yet again.
Compare an Aussie Hilux, 4Runner and Surf of the same age and the Surf will have a more refined interior and more advanced features/gadgets. The base model Surf interior is probably equal in finish to the same age top model Aussie Hilux (even slightly later model Hilux's) if that is important to you. The Surf offers auto-hubs (vacuum controlled) which are handy, no getting out to lock/unlock hubs. Surf will have electric windows and air controls, some have separate rear fan/heater controls and
seat are more comfortable in a Surf. Surf seats are a common budget upgrade for a similar aged Hilux. The Surf had lots of little thing like this years before they were available in an Aussie Hilux, but as age gets to them, it also means more things can go wrong. Nobody can dispute that the gradual failure of these components with time, will add
fuel to the argument that an Aust delivered Hilux is more reliable. These greater comforts in a side by side comparison between Surf and Aussie Hilux make the Surf appear better value up front, but that is for you to decide as a nicer interior or greater parts availability/reliability will vary in priority for all buyers.
Good luck with your purchase
832762
