Thursday, Mar 11, 2004 at 15:46
Willem,
I am not familiair with exactly what pumps are in what 4x4's, but I think that most older 4X4's have the inline pumps. Rotary pumps are a relatively new design (by automotive standards) and I am pretty certain that the 1HZ motor is a rotary pump (had the thing for 10 years, now not 100% sure!!!). But I am certain that the older toyota diesels had the inline pumps.
Pretty easy to tell when looking at the pump itself, the inline ones have all the
fuel lines in a row while the rotary ones are like a circle on the back of the pump.
The rotary ones use the diesel
fuel itself to lubricate the pump while the inline ones use the engine's oil to lubricate the pump internals. Hence the inline ones do not contact the diesel.
According to the BP website, it seems that post-1995 diesels should not have any problems. I suspect that the Buna-N problem started to surface in California, which has had low sulphur fuels for many years, and manufactures changed the seal type (note-not confirmed, just an educated assumption here).
Any vehicle pre-1995 with a rotary pump "may" have a potential problem. But at that age, wear would certainly be a factor. Just make sure Buna-N seals are not used in any rebuild.
I am not convinced a 60% reduction in sulphur would have that much effect on a seal, but stranger things have happened. Either way, I would not place too much emphasis on it. All diesels in WA have now been running on low sulphur diesel for over 3 years and its the first time its been raised as an issue.
But, just to confuse the issue, I had to replace the seals in the diesel pump in my 1990 1HZ 80 series about a year ago after it started to leak. Hmmm... was it the low sulfur
fuel, or the fact it had done 300,000kms !!!
Mark
311740
