Hi all. First post here. Hope I'm in the right place.
I don't really want a proper 4WD, but I thought you guys might have the experience to set me on the right track with a toy one. My thing is bird photography, so I need to get around a bit. Up to now, I've done all my travelling in a Holden Barina - a little 1.4 litre toy car designed for the city. And in most respects it's perfect: cheap to buy, quiet enough on the highway, fantastic
fuel consumption, a 600km range on a 43 litre
tank, and all the room I need. I sometimes take it
places people say you need 4WD for, and as long as I take it gently it does surprisingly
well - but the bottom line is that it really isn't built for bad roads.
So what I really want is something the same as the Barina *except* with more ability off the bitumen. I don't want to go off-road, but I *do* want to be able to take on long stretches of bad road (corrugated gravel, potholes, and the like) without too much fear.
I'll almost certainly buy new, and I don't want to spend more than 20 - 30,000. I looked at the Holden Cruze first, because it's
well-priced, reasonably economical, and because my credit card gives me a $2500 discount if I get a Holden. The Cruze, however, has several drawbacks: tiny
fuel tank (41 litres - the range might be no more than 400k!) means poor range; too much wind noise on the highway (= arriving tired and stressed); decent ground clearance (180mm) given that I'm not planning any serious off-road stuff, but the lowest item is the exhaust manifold, which scares me - if I *do* hit a rock, I could be in major trouble.
What about a Rav 4? They are a bit more than I really want to spend, but is a Rav a more practical proposition for the outback roads I want to use?
Or should I look at something else entirely?
