Another diesel question
Submitted: Friday, Apr 02, 2004 at 15:14
Willem
I have been told by various diesel fundi's that a diesel engine does need to run regularly and for long distances if it needs to operate to its maximum efficiency.
So if I buy a 4.2 litre diesel 4by with 300,000 on the clock and the vehicle is 15 years of age then it should be a good thing. No?
Now if I am looking at a vehicle with a similar engine and similar age with only 160,000 on the clock, should I be wary of possible future engine problems? So instead of 20,000km per year this vehicle has only done about 10,000kms per year.
All answers appreciated
Reply By: Davoe - Friday, Apr 02, 2004 at 15:36
depends depends problem with 2nd hand vehicles you have very little idea about previos life. Diesals work most efficiently after warming up so if it has been started driven to the shops for milk then straight back etc etc then that would not be good as it is the heat of the motor that aids combustion (hence the glow plugs when cold) just as if it had 300,000 of hard towing that also wouldnt be good. I would always give more consideration to a low k unit perhaps paying more attention to wheather it was regulary serviced and wheather it blows smoke which could be an indicator of leading to sedentry life. 300,000 is starting to get up there even for a diesal. Sorry I havent really answered your q but in my opinion I wouldnt be concerned about low ks but rather how they were achieved certainly long runs are better for all cars not just diesals. fyi I have driven countles hzj utes with 4.2 motors while in the mining industry which can cop some abuse and I have never even heard of a motor expiring
52947
Follow Up By: Willem - Friday, Apr 02, 2004 at 23:32
Thanks Davoe I appreciate your comments.
314789
Reply By: Member - Jeff M (WA) - Friday, Apr 02, 2004 at 15:59
Willem, K's are K's are K's. The less the better. I've had two diesels now and both I bought with very low k's for their age. The first thing I did to the both of them was replace all hoses and belts because they had'nt been changed (not enough k's yet) but were 5 years old plus. If you watch out for things like that (just common sense) you won't have a problem. ie A timming blet might need replacing every 100,000km's but if it's 10 years old and only done 60,000kms I'd be changing it anyway!!
Just make sure the oil and filter has been changed on the dot. If the beast has had good oil in it 9 times out of 10 the ol' diesel will be happy for a long time yet!
52948
Follow Up By: Willem - Saturday, Apr 03, 2004 at 10:37
Thanks for your feedback, Jeff.
314819
Reply By: flappan - Friday, Apr 02, 2004 at 16:27
Its not only the motor you need to consider though.
I think the lower the K's , with proper servicing , even a town runner , would be preferable to a high K's vehicle.
52957
Follow Up By: Willem - Saturday, Apr 03, 2004 at 10:39
Thanks flappan...taking all comments on aboard. Will check out the servicing. I think that the 4by os a local one sold by the dealer and serviced by them.
314820
Reply By: Member - Des Lexik(SA) - Friday, Apr 02, 2004 at 16:44
G'day Willie, I also agree that servicing every 5,000 k's is the secret to engine longevity.
52961
Follow Up By: Willem - Friday, Apr 02, 2004 at 17:46
Hello Al,
Has the mad Scotsman arrived yet? I am on my way now to the Exhibition after running around for SWMBO all day. Talk tomorrow.
314739
Reply By: Davoe - Friday, Apr 02, 2004 at 16:53
Me again Willem A 15 yr old 4.2? That would be 1989, Toyota didnt graduate to the 4.2 1hz from the 4l 2h til 1990. Your not thinking of jumping ship are you?
52963
Follow Up By: Willem - Friday, Apr 02, 2004 at 17:41
Davoe,
Yes.....Thanks for you replies.....looking at Ford Maverick '89...next week...not keen on Ford badges but never say never again :0) It is a Nissan after all. 167,000 on the clock, twin tanks B/B, R/R, Side steps etc. Older person bought it on retirement...in his eighties now does not need vehicle....stealer wants too much for it(13,990). I will not pay that ....but we shall see.
314738
Follow Up By: Member - Eskimo - Friday, Apr 02, 2004 at 18:00
almost as old as you willem
I mean its 15 yrs old? do you really think it will be a good buy?
it could have serious corrosion from not doing any work....yes a engine will last longer if its used ...heating keeps the moisture out of the engine....when moisture oil and the other rubbish in the engine mix's it creates acids which 'eats' at the metal parts
314741
Follow Up By: Willem - Friday, Apr 02, 2004 at 23:37
Eski,
It has to suit my budget. No longer working like some or being a fridgie raking in the dosh. Have to stick to my means hence an older vehicle. Thanks for the advice.
314791
Reply By: duncs - Friday, Apr 02, 2004 at 20:50
Willem
I sold an 89 patrol with 385k on the clock. Original owner did very little, second owner ran over 1000ks per week just to get to work plus trips some of which worked the car very hard indeed. Think 4wd mag testing gear. I had it for about 8yrs and was somewhat of a compromise betweenthe first two owners. I used it as a city hack, touring this wide brown land and can it really get up there weekends with the boys.
The engine showed few signs of slowing down but other things started to let me down.
Suspension and steering components started to fail in a big way and then a brake calliper fell off. Oh yeah that was fun.
The vehicle you describe sounds like a pretty safe bet but possibly a bit exe.
Good luck
Duncs.
52985
Follow Up By: Willem - Friday, Apr 02, 2004 at 23:30
Thanks Duncs,
If the vehicle is to my liking I will have to get the price down as my budget does not stretch that far.
314788
Reply By: Member - Cocka - Friday, Apr 02, 2004 at 22:08
G'day Willem
We just got back from a plesant 4 days over your way. Flew to
Adelaide with a couple of friends to spend time eating our way through the Barossa. Gee it's dry out that way.
Re diesels and their history. I have a little theory about certain owners and their ability to drive a diesel as it was meant to be driven ie there are those who want them to perform like a high reving petrol eng as that is all they have ever been used to driving. As you know a diesel is basically about torque and can run slowly under load for years, so maybe checking the maintainance skills of a driver and the likely use to which the vehicle has been subjected raises another question in the tapestry of considerations.
Cheers old son.
53000
Follow Up By: Willem - Friday, Apr 02, 2004 at 23:45
Hi Cocka,
Ahhh...A good time can be had in the Barossa. We normally go to the Clate Food and Wine Festival in mid May. Good fare and good wines and take all the backroads home. Yes it is very dry. We have only had 12mm rain since New Year.
Thanks for the diesel thoughts.
Regards,
314794
Reply By: Bilbo - Friday, Apr 02, 2004 at 23:03
Willem,
I still own a 1989 Ford Mav trayback ute (as
well as 100 series TD Cruiser). I bought the Mav when it had done only 38K kms in 1991. It's now done 220K kms and all of it rough ( I mean ROUGH) bush work as a prospecting vehicle. Being an (ex) diesel mechanic, I changed oil and filter every 5000kms - religiously. It's bullet proof, still pulls like a train, burns no oil, makes a bit of black smoke if you accelerate hard - but the Nissan TD42 motors all seem to do that, in spite of injector changes. I know of many TD42 motors that have done 350,000 kms and still don't burn oil etc and can still pull a brick****house down. Willem, my Mav has had a tough life and I swear by it. It's now been put out to pasture on a mate's farm as a hack vehicle. But I know if I wanted to go from Kalgoorlie to
Darwin - cross country - then the MAV is the vehicle I know would do it - and back! Only probs I've had are a drivers side disc brake caliper that persistenetly jams and wears the pad and then the disc rotor - twice it's done it and you don't know it's done till it's too late. That and a few bulbs, batteries and a set of alternator brushes is about all. If I was still out prospecting for a living, the Mav would still be my vehicle. I'm glad I never sold it. I worship that vehicle. It never let me down. Toyotas 'Cruisers are comfortable and torquey -but Nissans are just plain TOUGH.
Bilbo
53011
Follow Up By: Willem - Friday, Apr 02, 2004 at 23:28
Bilbo,
Thanks for that wonderful report on the Mav/Nissan. I am very happy with my old bus which isn't very far from doing 500,000km. It is a very tough truck. I am of course looking for a just a little more comfort and diesel reliabilty and as I want to go into remote
places where only diesel is available. I will have to get in to a regime of thorough servicing and oil changes as I only do the petrol engine every 10,000.
314787
Reply By: cokeaddict - Saturday, Apr 03, 2004 at 10:17
Hi Willem,
Just my shillings worth here, Check it out mate, they are amazing cars for what they do. I wouldnt think twice. Just get the price down, 1989 models are going for around 10,000 these days.
I clocked 600,000 on my first one mate, still going strong when i sold it too. Sorry i did now, i miss the old girl.
Good luck mate, im sure u will know if its right for you.
Cheers Angelo
53036
Follow Up By: Willem - Saturday, Apr 03, 2004 at 10:47
Thanks Angelo...will check it out next week.
314821
Reply By: Paul's lot - Saturday, Apr 03, 2004 at 17:37
Do yourself a favour big guy, ask about the service history. the quickest way to kill any diesel engine is to leave the oil unchanged. When you do get on, it seems a little overboard but change the oil and filter every 5000km religiously and don't do 5minute runs all the time. It takes approx. 15 to 20 minutes running to get the iol heated and evaporate moisture and crap. Happy Hunting
53084
Reply By: Glenn D - Saturday, Apr 03, 2004 at 19:25
Bought a new ( different ) vehicle recently because we are going round Australia. My 84 pajero didn't make me feel too cofident in my driveway let alone up the cape. I really wanted an 80 series but for a few grand more I got a 3lt Patrol with a lot less km's. I know you said you had a limited budget but the whole drive line ,
suspension , bushes, etc has done the mileage along with the engine, If you know the cars history it makes it an easier question to answer. All things being equal Ireckon go for lower mileage!!
53092
