lokka diff lockers,how have you found them
Submitted: Tuesday, Apr 28, 2015 at 14:44
Member - Stuart and Gunny
Reply By: Matthew G3 - Tuesday, Apr 28, 2015 at 15:50
Hi S/G
I had one in the front of my 80 and loved it. It did tighten up the steering marginal, cornering not a problem as it lets go if you back off slightly or if you keep power on it can stay in with no problems. In 4wd hardly a noise, but in H2 with front hubs locked in it did click turning the wheel just un locking with no load. Only wish I did the back at the same time.
Matt
553023
Reply By: Tony B3 - Tuesday, Apr 28, 2015 at 17:19
The best investment I ever made on my 4by.
553027
Reply By: Member - jumpin - Tuesday, Apr 28, 2015 at 18:17
I have a Lockrght lokka in my 105 cruiser and it has been excellent .Reasonable price and not hard to install .Been across the Simpson and around the Flinders, Up to the Cape and back and around NSW without issue .
553030
Reply By: snow - Tuesday, Apr 28, 2015 at 18:18
I found und them by a quick online search and also by going to the likes TJM.
tsk tsk, sorry couldn't help myself
553031
Reply By: Michael H9 - Tuesday, Apr 28, 2015 at 19:26
I had one in the rear of my diesel Jeep Grand and while it was great off road, the Mercedes auto transmission couldn't handle the characteristics on road and would throw the engine into limp mode at some roundabouts. I have since found out it is a common thing with that auto. The petrol Jeeps with US autos don't have a problem. I don't know about other brands. The clickety click noise on corners when they are in the rear can be annoying.
553033
Reply By: 671 - Tuesday, Apr 28, 2015 at 19:30
I have had one in the front for eight years and 103,000 ks and would do it again anytime.
You will notice a slight difference in the steering but it is not worth worrying about. The car has never tried to drive on straight ahead like they can with manual lockers.
There is a lot of incorrect information about them on the net. The most common claim is they unlock while going around corners and that could leave you with an unlocked diff when you might suddenly needed it locked. The truth is they are unlocked, or in the process of unlocking, just about all the time. That is why you can put one in the rear and drive around a city all day. You can't do that with a manual locker.
They work by using engine applied torque to drive the wheel with the shortest distance to travel while the one with the longest distance to travel i.e around corners or up and over rocks etc, can roll ahead driven by road applied torque.
The moment a wheel looses traction, they will lock instantly. As soon as it regains traction, and that could be less than a metre further along the track, the unlocking process will start again providing one wheel has a longer distance to travel.
When you look at a typical bush track, or even a sealed road, the
wheels are just about always turning at different speeds. The diff is rarely fully locked and that is why you get a slightly heavier feel through the steering, not the very heavy feel that you get with the diff permanently locked.
553034
Follow Up By: Michael H9 - Wednesday, Apr 29, 2015 at 22:45
I think you should read this...
How a Lokka works
Straight from the manufacturer, they are locked all the time and unlock when there is a torque differential on a firm surface where both
wheels have traction. If I put my foot down going around a corner on tar, it would stop the lokka from unlocking and the inside wheel would burn rubber.
838828
Reply By: gbc - Tuesday, Apr 28, 2015 at 19:46
Another fan here. Front of a hilux for me. Best improvement for the money that you can buy.
I will say that
mine was an sr5 hilux with the electronic diff disconnect so when the Lokka was installed it dragged the driveshaft as
well which pressurised the front seal in the tranny case and made it leak twice. This was remedied by installing a couple of hubs off a Povo pack hilux. This issue was endemic to only sr5 hiluxes up to 2004. Shouldn't affect other vehicles as the ADD only disconnected one driveshaft from the diff - strange setup.
553035
Reply By: Angryz - Tuesday, Apr 28, 2015 at 20:19
Had one in the front of a GQ was great in most cases. Created under steer on muddy corner though. Have since had air lockers without any issues. I prefer the selectable lockers myself.
553037
Follow Up By: Jackolux - Tuesday, Apr 28, 2015 at 20:44
I had one in the front of a 2.8 Hilux , it was a good thing . Wouldn't have one in the rear ,
838786
Reply By: alhow - Wednesday, Apr 29, 2015 at 14:38
I had the Lockrite (
Richmond Gear), same thing. Best mod you can do to your 4By for the money.
Different to drive at first but your subconscious soon learns to the point you may think the locker (unlocker) has stopped working.
Highly recommend.
553056
Follow Up By: alhow - Wednesday, Apr 29, 2015 at 14:40
To follow up,
make sure it is set up properly as per instructions as this is key to their successful performance.
838809
Reply By: workhorse - Wednesday, Apr 29, 2015 at 18:23
Had one fitted in the front of my 2000 Courier diesel ute over 160,000 km ago and its great around the muddy steep farm paddocks, across the deserts, Fraser, makes it a much more capable vehicle and absolutely no problems.
553064
