Friday, May 01, 2015 at 09:31
hi
Toyota hilux current shape ,just out of warranty
Injectors are noisey as hell when cold
Toyota have had around 4-5 different injectors in these 3.0TD
Noise concerns me but is not a deal breaker
What your biggest enemy is wear and tare on the injector tip
The current is diamond tipped . This type of tip prevents bad spray patterns causing poor economy and power etc
Did I mention that we had 3 clutches under warranty
The clutch does not lock up all the time, although barely noticeable
Occures after u sit on a 100 kph for around 1 hr then accelerate . It feels weird .The fuel economy gets better after u get a good clutch
ECONOMY 10.0 lts per hundred 100% city
The Toyota varies 20kms per
tank
Ford
Ranger pk or pj
70,000kms injectors destroyed . As many have complained about after 30,000kms it is impossible to acheive the economy u would expect .
There are reports of the Pj 1st generation has problems with the computer [ECU] causing starting and economy problems
By comparison the economy on the
ranger varies 70-90 km per
tank
ECONOMY
12ltrs /100 100% city
14-17 ltrs per 100 towing
11 ltrs per 100 high way
This was from a single cab alloy tray 2wd hi rise 450 kg lighter than a 4x4 dual cab
EGR valve
Some later European run twin egr valves ,suppose to reduce the build up of carbon .
I say block the egr and re calibrate ecu
Swampfox
553137
Follow Up By: Jackolux - Friday, May 01, 2015 at 21:18
Noisey injectors when cold is a sure
sign they need replacing , don't just ignore it , it could end up costing a lot more than just a injector job .
At least go to a Diesel Service and get them to check the values .
838939
Follow Up By: TerraFirma - Friday, May 01, 2015 at 23:16
Not sure that's true Jacko.? Cold start noise has been around a long time even with many new vehicles, I'm up to 300,000 KM's in a Hliux with one set replaced.Going better than ever, on a real cold morning it rattles for a minute or 2 but all good. It is worth saying prices have dropped dramatically for CR Injectors and the quality has improved. Be fussy about your diesel fuel, for me personally
Caltex Vortex Premium Diesel is where it's at until BP get their Ultimate Diesel in all states, there is no better.
838941
Follow Up By: Jackolux - Saturday, May 02, 2015 at 07:14
Yes Terra , you are correct I probably shouldn't of said a sure
sign , he did say as noisey as Hell , dunno how noisey Hell is . When my first linjectors buggered up , I would of said that was as noisey as Hell
Still worth getting the injector values checked .
I did a lot of research about injector problems when I had my Hilux ,
I talked to quite a few Fuel Injection
Services and got a lot of different stories as to why there was a problem .
I have just bought a new Dmax and have only used
Caltex Vortex so far but when traveling the OutBack a lot of the time you just have to take what you can get .
838948
Follow Up By: swampfox - Saturday, May 02, 2015 at 12:52
hi
Sounds like typical diesel knock when cold .I must say although the
Ranger injectors were completely stuffed they were never noisy .
Just remembered if u have ever decreasing economy as i stated before. My economy went down to 325 km per
tank .The dealer did not think it was an issue .[Ya kidding arnt u !!!!! ] THE SCAN TOOL SAYS IT OK WE CANNOT UNDESTAND IT. The scan tool cannot look at the quality of the spray pattern . I demanded they be removed and sent out for testing . Injectors were stuffed . After all that one of the new injectors lasted 2weeks then failed .
Around $500 each 2013
Dealers are turning into the I phone generation !!! aggh bloody useless
swampfox
838962
