looking to do up my sahara
Submitted: Wednesday, May 13, 2015 at 16:02
ThreadID: 117838 Views:3493 Replies:6 FollowUps:20
been quoted $1375 for a duel battery system for my beast i thi k that is a bit high also trying to get a good price on arb winch bull bar an scrubbers an side steps any suggestions regards Al western australia
Reply By: mountainman - Wednesday, May 13, 2015 at 16:53
ha ha..
if you honestly think 1375 is dear for a dual battery system, you wont be even able to stand up after getting a price for the bar work..
honestly your best bet is join LCOOL forum and chase up some second hand stuff...
its a landcruiser forum.
id be guestimating that youll be looking at least 4500-5500, all up and that's the lower end in the "new stuff".
second hand could be quite reasonable, around 3k should get you everything, but the stuffing around and right colour/ matching....as people update and try to recoup their costs and re standard their wagons and sell the bars...and stuff.
AnswerID: 553703
Follow Up By: Michaeljp - Wednesday, May 13, 2015 at 17:20
Did you get a break down on the costs? When i got a quote some time ago it was something like $600 for a redarc bcdc, $400 for a deep cycle battery and a few hundred for labour. It all adds up to big dollars if you get someone else to do it.
FollowupID: 839595
Follow Up By: Member - Bentaxle - Wednesday, May 13, 2015 at 17:36
I'm doing my own with parts sourced from EBay and have cut my $1500 quote down to about $600
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
FollowupID: 839596
Follow Up By: Member - 2517. - Wednesday, May 13, 2015 at 17:50
All you need to do is isolate the battery,have a read on this site,you do not need all this fancy gear that people seem to push.
FollowupID: 839597
Follow Up By: Gronk - Wednesday, May 13, 2015 at 18:12
You are right, a $65 GSL isolator, use the original 2nd battery for a few yrs until a new one is needed, and $40 max for some wire ( maybe a bit more if you want to run wiring to rear of 4wd )..too easy.
I have a 200 with an OL bar, which was less than $2000 colour coded and fitted, and quality and strength seems just as good as ARB..
There are ways to get value for money without compromising quality !
FollowupID: 839600
Follow Up By: Stu & "Bob" - Thursday, May 14, 2015 at 07:41
You need to keep your eyes open when searching for "stuff".
I picked up an ARB winch bar for my 200 at the ARB garage sale last year for $1K, came with a new fit kit, I welded on extra antenna mounts and gave it a respray.
A mate gave me a hand to fit it, we bumbled along, took us most of the day.
FollowupID: 839620
Follow Up By: mountainman - Thursday, May 14, 2015 at 17:02
AWESOME, well done on the finds, cheaper the better, you can shop for my next car now :-P
still you've got to get the other bar work..
also with the batteries, you might want to look at CAT batteries..
175-4390 product number, 1000CCA for 145, try beating that in your finds ;-)
Brilliant warranty, and superb starting grunt for any vehicle..
FollowupID: 839637
Reply By: TomH - Wednesday, May 13, 2015 at 17:52
You dont say what model and year Sahara but if its a 100ser or later it should cost about $130 for a Redarc isolater $40 for cable and the battery.
Thats all it cost me to do it myself.
Pretty easy to do.
AnswerID: 553707
Follow Up By: Flighty ( WA ) - Wednesday, May 13, 2015 at 18:11
Totally agree, most auto sparkys take about an hour to wire them in, and all you need to do is fit the hardware ie; battery holder & isolator unit.
And you get the satisfaction of knowing it's working properly after they test it when finished.
Flighty
FollowupID: 839599
Reply By: Member - Phil G (SA) - Wednesday, May 13, 2015 at 21:00
100 Series and 200series diesels already have twin batteries so all you need to do is isolate the two. Some places make it all unnecessarily complex by adding a 3rd battery/tray/blah blah blah.
Both vehicles start fine from a single N70 size cranking battery.
Then you need a fused cable running to the rear fridge and accessories....then you need the anderson plug etc etc so I can understand that time/costs can add up.
In my opinion, I've seen a huge number of dodgy DIY battery installations, so if you are not 12V competent and good at crimping/soldering/fuses etc, then just spend the money and get someone to do it.
Finally the question will arise about DC-DC chargers instead of a simple isolator, having run both and experimented over the past couple of years, in my opinion a simple isolator (eg Redarc solenoid type) is fine if the 2nd battery is under the bonnet; if the second battery is in the back, or in the van, then fit a DC-DC isolator.
AnswerID: 553715
Follow Up By: Member - Phil G (SA) - Wednesday, May 13, 2015 at 21:04
Oh and forgot to add that the bullbar/rails etc is all bad news .....costs you heaps!! ARB bar will be $2.5-3K
We used to say that every 4wd accessory sets you back $1000......but these days every 4wd accessory sets you back $2000k.
FollowupID: 839612
Follow Up By: TomH - Wednesday, May 13, 2015 at 21:13
The batteries in a 100 ser are only about 400CCA and are hooked together as one to give starting ability.
When you split them you normally replace both with something like 650 CCA ones. N70 as you say are good
I used 2 gauge cable the same as in the car to run to the isolator with professionally crimped ends.
Ran a 4 gauge to a Fuse block for rear circuits and a 4 gauge to rear for van batteries and 6 gauge for van fridge via 2 Anderson plugs
Waeco in the car had a Raps 12 to run it. All connectors were crimped with a professional crimper.
Total cost about $260 plus the batteries Ran for 2 years without problems.
Not hard to do as I measured all the cables and got a battery guy to crimp them for me after buying the cable and batteries from him.
Spent a day fitting it all up.
Simples
FollowupID: 839614
Follow Up By: vk1dx - Thursday, May 14, 2015 at 10:09
I don't know about pitting a third battery is a lot of hot air Phil (blah, blah, blah).
For long remote trips (CSR - three weeks) or when we will be stationary for more than two nights we installed a third battery so that the two fridges keep our food chilled and frozen. Otherwise we would have to fill the car up with solar cells and/or a generator plus fuel. A third battery fits nicely under the bonnet.
We split the factory two and added a third to the "second" one as a 4WD dual bank which can be used for starting if needed (rarely - only in the snow) with the aid of a switch in the cabin and a Redarc 200 amp isolator under the bonnet. All three are 105AH All rounders. The fidges ran for four days on test at home before I stopped the test. The single crank was not used.
DIY - Careful recommending this
I will never again lead anyone who does their own work and don't get it checked by, or isn't, a good qualified and experienced 4WD mechanic. Three of the cars in a mob that I led to a CSR trip didn't even get past Billiluna because of bad workmanship. Despite being asked strongly to get their DIY work checked!!!!
So please people don't push the DIY work system for critical tasks like rewiring the batteries, greasing bearings, fitting a long range tank or new alternator etc. Bar work maybe okay.Services possibly, but how many have heard the stories about drain plugs coming loose. The DIY maintained alternator came loose, and broke, on one of the tag-a-longs.
FollowupID: 839625
Follow Up By: vk1dx - Thursday, May 14, 2015 at 10:10
PS
Phil sorry mate that was not supposed to be an attack. Some of us have valid reason to fit extra items.
FollowupID: 839626
Follow Up By: Member - Phil G (SA) - Thursday, May 14, 2015 at 12:46
Nah, all good - thought your comments were fine, and thought my comment could have been worded better! But the original question was for dual batteries, not triple. And the point which I should have explained better is that some companies (eg ARB) will keep the original pair of batteries as crankers, and fit a third (smaller 10") battery as a single auxillary. You pay a lot for that type of installation (tray, relocation of bits etc) and only get 70Ah to show for it.
If I was running 2 fridges, I would have considered doing the same as you. But as it turns out the original poster has a 200series and it's a big struggle to get a 3rd battery under the bonnet, as the fuel filter becomes almost inaccessible when relocated.
FollowupID: 839629
Follow Up By: Member - Phil G (SA) - Thursday, May 14, 2015 at 12:50
Tom, out of interest, the original batteries in the 200series are now 530cca each and I've known people who have kept them after splitting and say a single one cranks fine. But it's not what you or I would do. Most N70 crankers now are over 700cca, which is plenty for the TTDV8.
FollowupID: 839630
Follow Up By: vk1dx - Thursday, May 14, 2015 at 13:07
The fuel filter was a problem, but thanks to the conscientious mechanic who went to the trouble of an extensive search and found a good carrier and also reinforced the side wall, all is good.
Crowded - Yoi ain't kidding . . . .
Catchya
FollowupID: 839632
Reply By: al s - Wednesday, May 13, 2015 at 21:06
1375 is with me supplying batteries
AnswerID: 553716
Follow Up By: Member - Boobook - Thursday, May 14, 2015 at 07:11
If you have a 200 and being quoted for a 3rd battery run away.
There is no reason for a 3rd battery other than to help ARB's share price. In fact Toyota put out a email specifically advising against it.
As Phil mentioned above, get a Redarc Isolator, split the batteries and replace them with larger ones and you are done.
Also DC - DC chargers are a solution waiting for a problem. Don't get one.
FollowupID: 839616
Follow Up By: Gronk - Thursday, May 14, 2015 at 17:05
If I needed the extra capacity of a 3rd battery, and seeing as it would probably be a fridge ( or two ), then the 3rd batt would go in the back of the 200...not under the bonnet..
But back to the original post......split the 2 batts already there, put in an isolator and save a heap of $$..
When the aux battery dies in 2 or 3 yrs, buy a new deep cycle one then !!
FollowupID: 839638
Reply By: al s - Wednesday, May 13, 2015 at 21:11
yes i got a few quotes for stuff draws and cargo barrier with drop down msa fridge bracket $4500 what a joke $850 for a safari snorkel fitted some ppl just want to rip ya off I have a 2012 landcruiser Sahara 200 upgrade
AnswerID: 553718
Follow Up By: Crusier 91 - Thursday, May 14, 2015 at 07:50
Get a quote from ARB, Safari snorkel is around the $650 fitted, MSA drop down slide sounds about right, they are very popular and have gone up in price since I purchased, I have to say there are very easy to install yourself which can save you a few bucks.The battery tray under the hood is around the $200 mark plus install, wiring and redac isolator, the whole kit should be around $600-$800 fitted with you supplying battery. Rear draws can be priced what you have been quoted for a ute tray in a triton, the landcruiser's rear is a lot smaller so i would expect it to be cheaper anywhere from $2500-$3000 depending on quality.
FollowupID: 839621
Reply By: Michael ( Moss Vale NSW) - Wednesday, May 13, 2015 at 21:39
You could just buy the second battery holder and a similar battery to your original and parallel them together with an isolator or simply run both batteries in parallel on a permanent basis like I do, save a heap of cash and the disappointment of a poor quality mounting and wiring by people who have a set time to install it. Michael
AnswerID: 553719
Follow Up By: wholehog- Wednesday, May 13, 2015 at 22:03
Same here...hard wired together for years..no problemo's. No isolators and electronic over priced junk in between them.
FollowupID: 839615
Follow Up By: Member - Phil G (SA) - Thursday, May 14, 2015 at 12:58
Gday Michael, trust you are well!
The irony of what you and Hog suggest is that the 200series TTD (that the original poster has) is wired exactly that way out of the factory. Twin batteries in parallel. Each battery is 65Ah - if you were to just do a battery change (to 2x 100Ah crankers) then you'll have a heap of capacity - just need a low voltage cutout on the fridge set fairly high.
Put a twin battery setup in my son's FJ Cruiser last week and wired it in parallel - I even used the big lead that came out of my 200. But he will only use it for short trips with daily driving so is unlikely to run it down. Only hassle is if one battery dies, you get 2 flat batteries.
Cheers, Phil
FollowupID: 839631
Follow Up By: Michael ( Moss Vale NSW) - Saturday, May 16, 2015 at 21:14
Hi Phil, I see the problem now. I wired mine in parallel as I have a very thirsty 90 litre fridge. I set the voltage cut out to 10.5 volts and it starts easily with the extra current from the pair. For me it save a lot of unecessary wiring and clutter. I agree about the one dead battery but fortunately haveny had that problem. A manual gearbox, old technology clunker like mine helps i guess! regards, Michael
FollowupID: 839729
