Friday, May 29, 2015 at 21:50
Yes John I made a cabinet with a fridge slide, there is a gap of about 30mm each side of the fridge and about 50mm above, a small fan is inside the compressor compartment of the fridge and two larger fans are in the rear of the cabinet, the fans provide plenty of air flow past both sides and top, the fans run only while the fridge runs. A control panel with charger switches, outlet power sockets,deep freeze,solar switch, etc,etc, is at the side
I removed all of the rear
seat and made a floor for the rear the same height as the back compartment, a 75 ltr
water bladder lays on the floor under the new floor, there is also room for awning poles under there as
I have done a lot of outback rough stuff with this setup and the only drama was when the Tailgate Lock stuffed up and there was no access to the fridge.
Don`t tell anyone, but I found you can open the locked tailgate with a 10mm spanner and a screwdriver.
Scrubby.
840477
