Friday, Jun 26, 2015 at 09:19
jokirt
The use of a small 240v battery charger may be no better than the uncontrolled 6-8 amp output of a generators 12v system.
The use of a suitable charger, ie, 15amp, and multi stage one if possible will use the generator most effectively.
Some people use the Honda Eu2 inbuilt charger but it too isn't regulated.
Charge rate ie, amp input, will decrease as the battery gets charged higher and higher. For large AH batteries a small 240v charger or using the inbuilt genny 12v system is poor.
Both require high revs of the generator to work at all.
The 240v charger will use the ECO setting and run fast enough to supply the required amount of energy AND charge the batteries quicker.
Saves on excessive wear and tear and
fuel too.
I have found some people running EU2i generators flat out while using a 240v charger. "Cos it said to do that when battery charging". WRONG.
The understanding of the concepts involved and operating at the time was somehow lost via the handbook wording.
842517
