Exhaust info
Submitted: Friday, Jul 24, 2015 at 18:22
Greg M15
Just wondering if any one has used a Domin8r Exhaust how has performed and was it easy to fit your self
Cheers Greg
Reply By: Whirlwinder - Friday, Jul 24, 2015 at 21:24
Yes Greg, I just fitted one to our 76 series Landcruiser V8 and it fitted perfectly but the 3 turbo flange nuts were a bugger to get off and on.
It sounds good but with no drone. I recommend them.
557362
Follow Up By: Greg M15 - Friday, Jul 24, 2015 at 22:16
Did it make any difference in your power or
fuel economy
Cheers Greg
843677
Follow Up By: Whirlwinder - Saturday, Jul 25, 2015 at 09:51
I have yet to do a serious check but am about to leave on a 6 week, 8000kms trip so i should know after that.
It might be a bit hard to know as the V8 has so much grunt in standard trim anyway.
843686
Follow Up By: Greg M15 - Monday, Jul 27, 2015 at 20:18
You said the 3 turbo bolts were a bugger to get on and is that because on the land cruiser or the fault of the new exhaust
Also is it a 3inch from the turbo dump ?
Also any reason why you chose this system over say the beau desert system just not sure which way to go
Cheers Greg
843763
Follow Up By: Whirlwinder - Monday, Jul 27, 2015 at 20:58
Greg. The turbo bolts needed the attention of the local exhaust fitter to heat them with oxy before they would release. Also the access is very tight and he used small socket set to do the job. The clearance between the pipe and the stud is so small that the nuts have to be started as the pipe is slipped on and tightened as you go.
Yes, it is 3" all the way but the turbo outlet pipe is less than 3" and the system matches it and then to 3" ASAP (about 100mm).
Cost was a major factor and as I am not fitting a chip I was happy with this level of performance. I am sure
Beaudesert and Manta are bit better in improvement but I am more than happy with the result even towing a Kimberely.
Cheers, Ian
843767
Follow Up By: Whirlwinder - Monday, Jul 27, 2015 at 21:05
Greg, one more thing. I replaced the Toyota
snorkel top with a safari type. The wind noise just went away and I think the air must be now
going where it should.....down the
snorkel and that should benefit performance.
Ian
843768
