Friday, Apr 16, 2004 at 22:16
A blow off valve will only work if the turbo is overboosting, which would mean flat changing, and low end lag wont be fixed by sequential turbo, unless you can identify the source of the low end lag, like my 90 series prado td, it has low end lag in standard form, becuase the
fuel is very lean down low to pass emmissions, so that would be
fuel lag, not enough
fuel burning to boost the turbo, so when you overcome this, the turbo boosts faster, which makes the engine burn more
fuel more rapidly, which boost the turbo, which makes more power, and so on, so the faster things can be made to happen down low, the faster it multiplies as you accelerate.
Lag is lag, regardless.....
316284
