Snorkel good, what about air box?
Submitted: Wednesday, Apr 21, 2004 at 14:13
Member - Jeff M (WA)
Ok, so I've now got my safari
snorkel, looks great, makes a nice rumble and low revs, and I'm sure the air is colder and cleaner. But what about the airbox? I'm not planning on getting the
water up to the windscreen, but would like to know that my hard earned $$$ spent on the
snorkel is actually going to save my engine if it comes down to the crunch. (pardon the pun!)
The surfs got a round metal airbox (same as hilux etc), it has metal clips that lock it on, however I doubt that it would be very
water tight, what have other people done if anything to have that little extra peice of mind? Or am I worrying about nothing...
Reply By: GO_OFFROAD - Wednesday, Apr 21, 2004 at 14:30
Put the lid on, then 100mph tape around the lid and air cleaner box, [one lap of tape] then put the clamps on, easy to remove, cheap, and can be done on the road when required.
55309
Reply By: Rosco - Bris. - Wednesday, Apr 21, 2004 at 15:45
Jeff
Usually it's a pretty good seal, otherwise dust etc would get in and bypass the filter element. If you're still uncertain ... go with the duct tape.
55324
Follow Up By: Member - Jeff M (WA) - Wednesday, Apr 21, 2004 at 16:58
Rosco, the filter is pushed into the other end of the air box in a round cylinder arrangment so if dust got into the box it would still have to get into throught filter to go into the engine. But if it's pretty good anyhow I won't worry too much about it, always carry duct tape anyway, so if it's a biggy I can double insure myself I spose.
317135
Reply By: Member - Roachie (SA) - Wednesday, Apr 21, 2004 at 15:56
Jeff,
The tape shouldn't be needed unless the clamps don't seem to be holding the lid down tight enough. There should be a rubber "O" ring seal between the lid and the canister. If that's in good nick and the clamps are tight, how can
water by-pass it?
JMHO
Roachie
55325
Follow Up By: Member - Jeff M (WA) - Wednesday, Apr 21, 2004 at 17:00
Fair enough Roachie, I must admit I didn't realise there was an "o" ring there, normally I just unclicp grab filter and blow air through it, not paying too much attention, I will have a look and see if there is one and what kind of condition it's in. The clamps are tigher than a ... So shouldn't be a problem. Thanks guys!
317136
Follow Up By: Member - Roachie (SA) - Wednesday, Apr 21, 2004 at 17:10
Good idea Jeff,
I don't have a vehicle like yours so I'm only assuming that it would simply be sound engineering practice to have a rubber seal....I could be wrong (have been plenty of times in the past...LOL)
Roachie
317141
Reply By: floyd - Wednesday, Apr 21, 2004 at 17:26
There will be a rubber
water draining hole in the bottom of the air box too to let any small amounts of
water out of the airbox. When going through deep
water tape over this so as
water does not come back up into the airbox and into the inlet pipe. When you have crossed the
water take the tape off again and it will drain
water out. My Hilux occasionally gets a bit of
water down the snorkle in heavy rain.
55347
Follow Up By: Member - Jeff M (WA) - Wednesday, Apr 21, 2004 at 17:34
Ah, that explains the other question... It's actually raining here today, and I was wondering what happens, I figured it must suck at least some
water in the rain, thinking strange as I just spend $$$ to stop
water getting in there!! ;-) But yeah, now you mention it my rocky had a drain hole on the bottom at it was the same air box, I'm glad I checked as that would deffinatally need to be sealed up in deep crossings.
Thanks!
317147
Follow Up By: Member - George (WA) - Wednesday, Apr 21, 2004 at 21:32
No one has ever mentioned other breather pipes that disappear under
water, what happens here, particularly if you are stuck in say 500-600mm depth
water ????
317216
Follow Up By: floyd - Thursday, Apr 22, 2004 at 18:06
Just do a search of the
forum under "breathers" as in diff, gearbox etc and you will get a heap of solutions for stopping
water getting in those
places too.
317398
Follow Up By: Glenn D - Thursday, Apr 22, 2004 at 18:29
Hi ,
Just bought a new snorkle ( safari ). It has vents in the inlet ( top 90 degree bit ) to let
water out . Have checked air filter afer wet weather and it is dry . The safari install manual says to seal the drain hole with sealant .
317403
Follow Up By: Member - Jeff M (WA) - Thursday, Apr 22, 2004 at 18:38
Glen D, thanks! That would make perfect sense. I actually pulled the air box open last night under tourch light and there is a rubber seal around it, I'll have to look at the drain hole and see if opposite lock sealed it. I did notice he has put some silicone around the air temp sensor which I was glad to see.
317405
Reply By: DiesAl - Wednesday, Apr 21, 2004 at 23:15
Gday Jeff, it's also worth checking that the fitters sealed your
snorkel properly, have read a few horror stories about this not being done as
well as it could be so you end up with a useless
snorkel............Still looks good though...LOL.
55413
Reply By: Bundyman - Thursday, Apr 22, 2004 at 00:12
Jeff. you'll be amazed at the amount of air a diesel sucks through the filter even at idle!! The best way to give piece of mind is get an assistant to place say an ice-cream bucket lid over the intake (top of
snorkel) while the engine is idling while you pass a lit cigarette around any joins in the
snorkel or the top of the air cleaner etc. Only be able to do this in short hits otherwise the engine will conk out, but it will allow you to see any leaks because it will suck the smoke in. Obviously do it in your garage where there is no wind. Pays to put a light film of rubber grease (grab a finger full from you tyre
shop) around the o-ring seal at the top of the air cleaner and silicon up any other leaks you find. Hope this helps.
Hughesy
55424
Follow Up By: Member - Jeff M (WA) - Thursday, Apr 22, 2004 at 10:16
hee hee, yeah at idle standing next to the car you can here it sucking and rumbling. It was such a quiet engine before...
But yeah great idea, will have to give it a go on the weekend.
317303
