Tuesday, Apr 27, 2004 at 16:19
Paul be careful before using avgas in any automobile there are severe penalties for using leaded
fuel in motor vehicles without the proper authorisations. The following info might be helpful
"It is now an offence in Australia to add lead, or any other prohibited substance, to motor
fuel or to use leaded
fuel, (other than for aviation) – maximum penalty $110,000!!!
However, The Minister for the Environment has granted exemptions to allow the supply of Avgas and leaded racing fuels (eg RF100) via certain approved organizations for a limited period, currently to June, 2005. The bureaucrats hope/expect that demand from motor sport will have dried up or disappeared by then, but it could be extended if there is sufficient demand and a strong enough case is made. (“Users of vehicles that have a requirement to use leaded
fuel are encouraged to seek alternatives.”)
Currently, there are 22 approved “Issuing Organizations”, mainly speedboat, hot rod, and speedway, but including CAMS and the Australian Historic Motoring Federation (GPO Box 2862,
Canberra, ACT, 2601). These groups issue “Leaded
Fuel Passbooks”, on behalf of the government, to members of their associated clubs which allow the purchase of Avgas from your local supplier (mainly airports and race circuits.)
CAMS will only issue Passbooks for cars with CAMS Logbooks; however AHMF will issue them on a wider basis. AHMF is the peak national motoring club organization and covers 900 motor clubs (for example, via AOMC in Victoria, the Council of Motoring Clubs in NSW, etc). Most motoring clubs are (or should be) a member of one of these organizations. If you need a logbook, give AHMF a call (Ph 0419 249 109, or email gittins@eisa.net.au). You will need an application form and $20. "
Pete
56226
