troopy radiator leak
Submitted: Friday, May 07, 2004 at 21:10
Member - glenno (QLD)
I got home and i could smell a coolant type smell . I can see where coolant has been running down the radiator fins . Looks like it is leaking from the top . I can hear dripping coolant . Lost about 2 litres . Has anyone else had this problem with troopy radiators . I guess they replace the top , i dont know .
Reply By: Goran - Friday, May 07, 2004 at 21:46
You probably have cracked radiator top section (plastic). If i where you i would replace whole radiator with heavy duty tropical unit. What you have is common fault with Toyota radiators. As soon as i spot one drop from the radiator i will do the same with
mine.
57680
Follow Up By: Member - glenno (QLD) - Saturday, May 08, 2004 at 08:49
thanks goran
319463
Reply By: Member - Pesty (SA) - Saturday, May 08, 2004 at 00:27
Chuck the plastic one and for similar money you can get a good old fashioned soldered one that can be repaired in the bush if needed. You will have to ring around up there for a supplier.
57699
thanks pesty
319464
Reply By: Peter 2 - Saturday, May 08, 2004 at 07:48
Common problem even with the older metal radiators in Toyota's, usually the first and second tubes just in at the top on the RHS (drivers side). They always seem to let go at these two points first. If it is a metal radiator and is basically sound have your friendly radiator place chop the offending tubes off and solder them up, you will probably have no more probs.
The metal ones also tend to crack around the seam where the tanks are soldered on too.
If there is any question over the condition of the radiator it would be best to replace it with a new full metal one, radiators are much cheaper than engines.
57706
Follow Up By: Member - glenno (QLD) - Saturday, May 08, 2004 at 08:50
thanks peter2
319465
Reply By: The Banjo - Saturday, May 08, 2004 at 09:08
Glenno.....radiator maintenance in the hands of a pro is quite straight forward....it can be fixed for moderate expense but like the others suggested a superior replacement is the go if you are going to keep the machine. My Mazda Bravo sprung a top
tank leak some years back........put in an after market TWIN core all metal unit (brass I think)..........your radiator specialist will know all about them (can't recall the brand now). I got old fashioned performance and reliability, with improved cooling capacity. Might be $400-$500 when its all over but it'll be the last radiator you put in I'd guess.
57709
Follow Up By: Member - glenno (QLD) - Saturday, May 08, 2004 at 09:25
thank you the banjo
319467
Reply By: Member Eric - Sunday, May 09, 2004 at 11:18
I had the same problem on my 80 , sent the raidiator out for a full rebuild and new top
tank. Havent had any more leaks for 100,000 kms
57819
Follow Up By: Member - glenno (QLD) - Sunday, May 09, 2004 at 12:40
Yeah Eric, i will see how much for new top
tank not plastic. thanks
319581
