gu patrol rims
Submitted: Tuesday, Aug 25, 2015 at 19:42
ThreadID: 130093 Views:2462 Replies:4 FollowUps:0
Hi i have a 2006 gu patrol wagon 3.0 litre turbo diesel. Looking at getting new rims and tyres. Will a 16 by 8 rim fit or do i have to stay with 17. Also what is the normal offset that peoplw get. Thanks heaps
Reply By: TomH - Tuesday, Aug 25, 2015 at 20:54
Try asking on the PATROL forum should get a quick correct answer
AnswerID: 589650
Reply By: Member - mechpete - Thursday, Aug 27, 2015 at 09:01
might be worth checkin the legalitys of it ,
goin from 17 back to 16in
mechpete
AnswerID: 589698
Reply By: Robin Miller - Thursday, Aug 27, 2015 at 10:26
Most but not all 16's will fit , it actually depends on the wheel rim offset which has the potential to rub on front brake calipers - which further depends on brake pad condition.
A negative offset is usually ok.
I have 4 sets of wheels , and on 1 set they just rubbed with new brake pads and I had 5mm aluminium spacers made up to fit.
On another set from Huntsman with zero offset I also got a very small scrap as wheel rotated , and just ground off the caliper edges a bit.
Note - the bigger front brakes of the 4800 are more of an issue
I also have Nissan 16 X 8 alloys from 2004 and they are fine with 285/75/16.
Also my set of trak II's steels are great and these are my most used wheels as they are light being only 16X7 with a10mm offset and can take the 265/75/16 size and whose combination makes the car more stable due to increased track.
AnswerID: 589700
Reply By: Capt. Wrongway - Thursday, Aug 27, 2015 at 16:31
I have 285/75/16's BFG Muds on 16" neg 13 off-set steel rims on my 2014 GU Patrol.
Looks great and fits with no problems.
Bazza
AnswerID: 589713
