Tuesday, Sep 22, 2015 at 22:28
Techedge
A CRD engine's high pressure pump ie, the actual injection pressure device, develops at least 10 times the pressure a conventional diesel develops in the injector lines. If chipped that pressure is/can be, 15 to 20 times higher.
The fact the pump is still a mechanical device and using a piston which is being displaced by a cam arrangement, those contact surfaces run at higher mechanical and sliding forces than the conventional diesel.
Having as much lubricity will definitely increase it's life.
The lubricity may also assist the life of injectors too.
A conventional diesel MAY suffer no appreciable ill effects, perhaps a shorter injector pump life judged over the normal life of a pump, BUT the CRD single sumps which supplies all
fuel to all cylinders does work hard and if there isn't enough lube between the vital surfaces the metallic surfaces may/can suddenly be destroyed.
If there is scuffing of those parts, they then shed fine metallic particles which have only one way to go, THROUGH the common rail and it's pressure relief valve and also through highly precise injectors too.
Injectors of such fine tolerances do not take kindly to anything other than
fuel going through them. Therefore they quickly deteriorate or suddenly fail.
If 2 stroke can provide the vital/essential lubricity, then it isn't such a bad idea to add a bit. Insurance is a nice thing to have, it is thought 2 stroke gives a degree of insurance.
If the pump and injectors last longer than one which doesn't have 2 stroke added, then it works. It is a long time in the test phase for 2 stroke use in normal CRD so a definitive result isn't readily at hand.
858644
