1HDT Surging
Submitted: Wednesday, Sep 30, 2015 at 11:01
ThreadID: 130463 Views:9673 Replies:9 FollowUps:4
Hey guys, I have a freshly rebuilt 1HDT, turbo, Injector pump, Injectors, Im having issues with a surge thats more prominent when I get above 90km/h, power is still then when you apply the accelerator but just a constant repetitive surging, am running out of ideas on what it could be, I have read a few posts about it being a bad earth or air intake or filters, all the filters are new and only done 1000km.
Reply By: vk1dx - Wednesday, Sep 30, 2015 at 11:26
I am not a mechanic so I can't help you if you did it yourself but if not then go back to who did it and get them to fix it.
AnswerID: 590891
Reply By: Life Member TourBoy, Bundaberg - Wednesday, Sep 30, 2015 at 11:30
I would tend to think that it may be a pump issue, I know they are different but the 1HZ surges when the pump isn't right.
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 590892
Reply By: maurice b - Wednesday, Sep 30, 2015 at 13:28
Hi Micheal , i had the same issue when i fitted the 1hdft to my 105 series ,strange how it occurred after fitment . In my case it was the fuel tank vent in the cap that was blocked starving it from air. I would think the diesel shop who rebuild the pump would honour there workmanship and correct your fault
AnswerID: 590897
Reply By: Michael W21 - Wednesday, Sep 30, 2015 at 13:36
I tried removing the fuel cap few days ago and still the same issue, Engine was rebuilt by the old man and I, pump was sent to perth to be rebuild(Got a few prices in Darwin and they were real rich around the 4.5k mark for a rebuild).
Tried running fuel lines to a independant fuel supply(aka coke bottle) and drove with the same issues.
Even going up through gears from 1-5 you get around 2.5-3.0+ you feel it pull back.
AnswerID: 590898
Reply By: Ron N - Wednesday, Sep 30, 2015 at 13:55
Michael - Surging in a diesel engine is generally caused by air in the fuel, or by fuel starvation.
Air can get into the fuel on the suction side of the pump via old, cracked hoses, loose connections, pinholes in steel lines caused by rust, and via old hardened or cracked seals on filters.
Crack a fuel injector line at the injector when the engine is idling, by slackening the nut just enough so that fuel leaks out.
If there's air getting in the fuel, bubbles should be visible.
However, if the leak is tiny, and only affecting the engine at highway RPM's, air may not be visible in the cracked fuel injector line at idle.
Alternatively, it could be a governor problem. But - if the pump has been overhauled properly, there should be no problem with the governor.
The other potential problem area of fuel starvation can be caused by a fuel line blockage - or the suction screen in the fuel tank could be blocked.
Visit your local fuel injection specialist, and they will soon put you right.
Cheers, Ron.
AnswerID: 590899
Reply By: mike39 - Thursday, Oct 01, 2015 at 07:33
You say the problem is more noticeable around/above 90kph.
This indicates the turbo is in boost mode, I would be looking at the wastegate diaphragm and mechanism, injection pump boost diaphragm (aneroid) and the piping in between.
mike
AnswerID: 590908
Follow Up By: Michael W 89 - Friday, Oct 02, 2015 at 21:47
Hey Mike so a turbo wastegate issue could cause surging at the high rpm?
FollowupID: 859141
Follow Up By: mike39 - Saturday, Oct 03, 2015 at 09:06
My feeling is that the problem is somewhere within the balance between turbo boost and pump boost diaphragm.
It could also be delamination of the inlet hose to the turbo.
A split in the flexible pipe between the turbo and wastegate caused a similar problem in my 300tdi Disco
mike
FollowupID: 859160
Reply By: member - mazcan - Thursday, Oct 01, 2015 at 18:25
hi Michael W21
just because the filters have only done 1000 km's doesn't mean they are not partially blocked (have you bought fuel since the filters were changed or are you still using the fuel you had in the tank/s before the repairs) and starving the engine of fuel to me the symptoms indicate lack of fuel or air in the system changing the fuel filters is an easy option and bleeding all the injectors at idle... are you sure one of the fuel filter seals isn't letting air in at road speed doesn't take much to cause surging
some filter bodies have square profile seals and others have round orings if the square profile type aren't seated correctly and are twisted they will let air through cheers
barry
AnswerID: 590939
Follow Up By: Michael W 89 - Friday, Oct 02, 2015 at 21:45
Hey Mazcan, I have ran a independant fuel supply straight to Injector pump to elinate anything before the Injevtor pump
FollowupID: 859140
Reply By: Stu & "Bob" - Friday, Oct 02, 2015 at 10:41
G'day,
When I had my 100 series, it did start to have these symptoms. The fuel filter was replaced, but the surging still carried on. When I swapped tanks, however, the surging vanished. On investigation, I discovered that the installer of my long range tank had put an in-line filter in the fuel line from the long range tank. When I removed it, the surging disappeared.
AnswerID: 591016
Follow Up By: Michael W 89 - Friday, Oct 02, 2015 at 21:44
I have ran an indepentant fuel supply straight to to the Injector pump to see if it was anything beyond the fuel filter back.
FollowupID: 859139
Reply By: Corncob - Wednesday, Oct 07, 2015 at 19:39
When these 1HDT Toyotas first came onto the market they had a issue with surging on some vehicles there was a mod bought out by denso and toyota to solve the problem if you contact your local denso diesel injection dealer they should be able to help you ,there was a major dealer in each state doing the mod,there is a toyota bulletin on it, the problem is that after a pump is overhauled it can become a issue through no fault of the diesel injector repairer i am involved the pump repair industry and it was a huge issue
AnswerID: 591324
