Saturday, Oct 03, 2015 at 13:24
Sorry Broodie,
I overlooked the Pathfinder bit. Realizing it isn't a leaf spring D40.
Most spring makers have up rated coils to suit loads and so some info from them would be good to have as they make
the springs which others sell, and so know what ratings they have, the
shop books don't necessarily have that info.
As above Dobinsons are a good start for a suitable spring.
Seeing you are using a heavy ball weight van, the shocks will need to have that increased capability mentioned and so I would seek out Bilstein or Koni which can dissipate the heat developed within the shocks oil, when used in/with continual corrugations etc.
B or K will have a suitable shock in their listing to suit the increased ride height, ie, a longer shock extended length, and will cater for the mass it has to control.
The 40mm increased ride height will give both ends the ability to absorb and slow down the movement so there is no bottoming of the
suspension at either end. (driven sensibly as you do). Bottoming is what kills chassis and axle/
suspension components.
With the Bilstein or Koni they have a single tube design on most and they allow heat of the oil to be dissipated more effectively/easily than a twin tube design where the heat can't get out to the outer tube fast enough, hence thinning of oil and loss of shock control ability.
If B or K, you may require a shield on the tube of the shock so it doesn't cop a whack from a stone (on the rears) and dent the tube. That would make the shock damaged.
I fitted Bilsteins to my 2011 Dmax and the handling and steering acuity and control vastly improved.
The OE shocks at 5000km were almost useless at anything other than looking like shocks.
Probably Nissan hasn't fitted high quality shocks in the first place,ie enough for sales purposes on a test drive, but they won't have any additional control capability which you will require.
859180
