Sunday, Nov 22, 2015 at 17:45
Howdy...
A couple of things, when working out the "basic empty weight" of my vehicle I stripped out everything that wasn't fixed or bolted in. I also put in a full
tank of
fuel, this way you can back solve the precise weight of
fuel and subtract that from the weight when you put it over the scales.
This will then give you a basic empty weight to work from.
I then use a load sheet to work out precisely what has gone into the vehicle, including
fuel, add it to the basic empty weight to arrive at the loaded weight.
Now don't worry, I don't do this every time I head down the driveway, but always before going "on tour".
On GVM upgrades, the absolute limit of the GVM is one thing, the other is the individual axle limits.
In my case, the GVM upgrade by Lovell's gave me a GVM of 3,900kg, which is above the combined axle limits of 3,780kg - Lovell's managed to get this approval for the 79 Series, no-one else has it. Having said that, the limiting factor for me loading the vehicle is the rear axle limit, not the actual GVM.
When I had a rear axle modification done I dropped the GVM back to 3,780kg to ensure compliance with the modification. In reality it had no impact as this was generally the maximum I could go to in any case without overloading the rear axle.
You can read more about it in my blog ...
When more is a burden...
Cheers, Baz - The Landy
861189
