Sunday, Jan 10, 2016 at 10:50
while what you are saying is absolutely true, replacing lamps in stop, tail and indicator lights is not the problem it is in headlights.
The ADR sections on headlights go hundreds of pages, while the sections on stop, tail and indicator lights go several pargraphs pluss some diagrams. The stop, tail and indicator sections mostly specifiy in fairly simple terms intensity and viewing angles.
It is possible with some care to select LED substitute lamps that will achieve or be very close to achieving practical compliance in an existing fitting for stop, tail and indicator.
It is not however possible to achieve practical compliance with a substitute lamp in an existing headlight fitting .... not even close.
The practical enforcement also differes greatly ...... The
police and inspectors are red hot on headlight compliance, because it is a known practical issue, but on stop, tail and indicator lights ...... as long as it is working, showing the correct colour, visable over the correct range and not rediculously
bright .... most officers will look no further.
863233
