Foil insulation on windows
Submitted: Wednesday, Jan 20, 2016 at 08:53
Geoff H18
Just reading the thread on fridge bags.I have a prado with the radio antennas attached to the back qtr glass.I was wondering if I were to atttach insulation with suction caps ,will this have a negative influence on radio reception?
Reply By: Allan B (Member, SunCoast) - Wednesday, Jan 20, 2016 at 09:41
Hi Geoff,
Probably would have no significant effect provided that the foil was insulated from any metal body.
Experience has shown me that antenna behaviour is not always predictable so try it and see. A preliminary test using alfoil and sticky tape may give some indication.
595181
Follow Up By: Geoff H18 - Wednesday, Jan 20, 2016 at 10:10
Thanks Alan
863837
Reply By: Kazza055 - Wednesday, Jan 20, 2016 at 09:48
As it will be on the inside I don't see it effecting the antenna.
I am about to do the same thing with the canopy windows on my D-Max. I went to Red Dot and picked up three screen shades for $2.99 each - cheap as chips ;=))
595182
Follow Up By: Malcom M - Thursday, Jan 21, 2016 at 06:51
Huh?
How does being on the inside surface of the glass affect your thinking?
The point is whether or not the metalised plastic surface of the screen has an adverse effect on the antenna. Glass has extremely little impact on RF signals.
863871
Reply By: MarkHugh - Wednesday, Jan 20, 2016 at 10:42
My view differs from those above; I am sure the foil will ruin the radio reception.
Mark
595184
Follow Up By: Member - Boobook - Wednesday, Jan 20, 2016 at 20:19
Yep, me too.
The radio waves don't care about inside or outside the glass. But they do care about the foil being between the antenna and the transmitter. It will block some signals and cause reflection interference on others.
863862
Reply By: Shaker - Wednesday, Jan 20, 2016 at 11:08
It is a
well known problem that even after market window tinting affects the Prado radio reception, check on PradoPoint.
I am thinking of changing to an external aerial.
595186
Follow Up By: Geoff H18 - Wednesday, Jan 20, 2016 at 11:20
Thanks Shaker,I got the non-metalic tint on the back windows
863841
Reply By: Member - ACD 1 - Wednesday, Jan 20, 2016 at 11:23
Geoff
I won't
hazard a guess at radio interference, but watch the use of suction cups on your windows.
I had
mine attached with suction cups and it started to lift the tinting. I don't know if it is a common problem or unique to me.
Anthony
595187
Reply By: Malcom M - Thursday, Jan 21, 2016 at 06:55
What sort of antennae are you talking about here. Is this an AM/FM radio, mobile phone, UHF etc?
Antennae behave differently at different frequencies. Depending on your application it will be disastrous or have little impact.
As you are using sticky cups, stick it on and find out for yourself...
595217
