Ford Ranger Tyre Monitors
Submitted: Tuesday, Feb 02, 2016 at 17:30
Member - Ellis F
Has anyone found someone who can disarm the factory fitted Tyre Monitor in the latest Ford
Ranger XLT PX Dual Cab. Our Ford dealer has no answer but say Ford Australia are working on a solution. The problem being if you fit another set of rims the monitor reads no connection with the new rims as it is trying to connect with the original sensors and keeps sending the warning beep to advise you which sends you mad after a short time. Any suggestions would be much appreciated
Ellis
Reply By: TomH - Tuesday, Feb 02, 2016 at 19:57
Why not fit the sensors to the new rims and reset the thing
Next best advice would be to look for a dedicated
Ranger Forum
595838
Follow Up By: Member - Ellis F - Tuesday, Feb 02, 2016 at 20:05
Thanks for your input. The reason I don't change the sensors is I have a second set of rims and tyres set up so they can be swapped when off-roading
864564
Reply By: Member - bill f (QLD) - Wednesday, Feb 03, 2016 at 02:09
Can you just put an on/off switch in the power line? Bill
595850
Reply By: Lachie - Wednesday, Feb 03, 2016 at 08:15
I have swapped my prado bfg's over to the ford
ranger on the day of delivery. Warning light always on.Will have to get them to look at it on the 5000 km service.
You don't know how do stop that stupid door ajar alarm ?
Regards Lachie
595854
Follow Up By: Member - Ellis F - Wednesday, Feb 03, 2016 at 10:22
Ford say they can't program the light to be turned off. Yes the door is annoying haven't found out how to stop it yet. If they got rid of a lot of the electronic rubbish it would be a much better vehicle!!
864596
Reply By: gbc - Wednesday, Feb 03, 2016 at 09:04
try over on newranger.net if nothing here - there are guys with similar setups but not sure if they have solved the TPMS issues yet - the new manual with the wiring diagrams is only just out.
595857
Reply By: Member - Ellis F - Wednesday, Feb 03, 2016 at 10:17
Thanks will have a look
595860
