Snatch block
Check out the size of the snatch block these guys use. we would just about need a trailer just for it.
Reply By: Allan B (Member, SunCoast) - Tuesday, Mar 01, 2016 at 17:53
Some serious recovery stuff there Doug.
But I think I would stand more clear of the cables than they did!
AnswerID: 596835
Follow Up By: Life Member-Doug T NSW - Tuesday, Mar 01, 2016 at 18:06
G'day Allan
Yes the same thought passed my mind when him standing close to the cable, they sure have some equipment.
FollowupID: 865790
Reply By: MUZBRY- Life member(Vic) - Tuesday, Mar 01, 2016 at 18:34
gday
I dont see a problem with what they are doing, as at least one of them would have an engineers degree on wire ropes and all things crane. But it was a nice big snatch block.
AnswerID: 596837
Follow Up By: vk1dx - Wednesday, Mar 02, 2016 at 14:20
Engineers degree Muz?? I doubt it. You don't need a degree to do that work. I was part of a team that did the same in Australia. No formal civilian qualification among our lot. Military training courses would suffice.
However one day we will need a degree to do it even if it is for all the OH&S stuff.
FollowupID: 865820
Follow Up By: Member - Damien L (Cairns) - Thursday, Mar 03, 2016 at 00:03
Phil, one day we all need a degree b4 we can drive a 4x4
Damien
Love the bush
FollowupID: 865841
Reply By: gbc - Tuesday, Mar 01, 2016 at 19:05
It's been a while but the rule for minimum sheave size is 18 x the wire rope diameter.
Who carries a 180mm diameter snatch block for their fourby winch? Pretty sure mine's only 110 mm odd.
Big sheaves = happy cable.
Those boys would know that is a light (comparatively) recovery. No big strain on any of the gear. Nothing like us dodgy weekend warriors.
AnswerID: 596838
Reply By: vk1dx - Tuesday, Mar 01, 2016 at 19:07
I did very much the same myself during nashos. Great memories.
Hated the wet ones though. Mainly because someone had to get down in the mud and put a small charge under it to break the hold that mud can have on the bottom of a flat tank rtc. Yuk!!! Luckily I never volunteered, nor did I get get volunteered, to do the scuba recovery course. You had to be stupid or chasing rank to do that one. Me NOPE!
Here we are building a bridge at Canungra. And a side view of a similar truck with tank recovery trailer in tow.
AnswerID: 596839
Follow Up By: Life Member-Doug T NSW - Tuesday, Mar 01, 2016 at 19:46
G'day Phil
wow you hit a soft nerve with that bottom photo, I would love to have one of those all nicely done up.. Thanks for the fab pics mate.
FollowupID: 865797
Follow Up By: Life Member-Doug T NSW - Tuesday, Mar 01, 2016 at 19:50
Phil I just noticed the 2 black marks, looks like there might be something the public was not meant to see.
FollowupID: 865798
Follow Up By: vk1dx - Tuesday, Mar 01, 2016 at 20:55
Knowing the yanks Doug it could be anything from a gum dispenser to a rocket launcher.
How about one of these. Looks brutal as well.
Aust Army Mack R600
FollowupID: 865805
Follow Up By: Member - ACD 1 - Tuesday, Mar 01, 2016 at 21:57
Let's not get carried away with some sort of conspiracy theory...
....they're eyebrows over the two red eyes.
Anthony
FollowupID: 865807
Follow Up By: vk1dx - Tuesday, Mar 01, 2016 at 22:26
Hi Anthony, any of these eyebrows?
eyebrows !!!!!
FollowupID: 865809
Reply By: J&A&KK - Tuesday, Mar 01, 2016 at 22:11
Looks like a training excercise to me. No mud that I can see. Tank has thrown a track so usually you stop after you have driven off the broken track. Unusual to try to keep going as the result is always the same unless on really hard ground. Have done a few D8 track chain reinstallations in the jungle in real mud. Not fun. Those guys have a lot of kit available. No real stress just time and great to be able to drive right up to the broken kit. In real life it's always " a bridge too far" and a lot of bastardry with available kit.
AnswerID: 596842
Reply By: Ron N - Wednesday, Mar 02, 2016 at 13:36
Those blokes have all the best gear! - and that's not mud!! The pics below show REAL MUD!
Where 200L oil drums sank level to their tops overnight! - and the top of the Cat D8 tracks were level with the ground!
The Centurions were carefully picking the shallow areas to stop them from becoming bellied!
Mud!
More mud!
Cheers, Ron.
AnswerID: 596854
Follow Up By: vk1dx - Thursday, Mar 03, 2016 at 07:14
Hi Ron
At the ripe old age of five, I remember sitting in the front of an old Yankee jeep, up on the Bogong High Plains next to my big brother and being towed by a big dozer (unknown type) through a bog hole with mud seeping over the bonnet and into our lap. We forgot the windscreen was down!!Well my big brother forgot it. I was only five. He was 18 years older than me.
Didn't Mum go off the deep end. We had to go out the back and strip off. It was winter and we lived in My Beauty. Cold!!!
Memories.
FollowupID: 865845
Follow Up By: Ron N - Thursday, Mar 03, 2016 at 10:09
Phil - Yes, I think most of us have been there and done that.
God knows how many dozers I;ve extracted from bogs where the mud was over the floor plates.
Tying a log to the tracks worked 98% of the time - but then there were the times when you couldn't get near the machine with anything else.
Times when you'd push a 6 foot (1.8M) crowbar straight into the ground, and it would disappear out of sight, without touching bottom!
In SVN, one bloke bogged a Cat D7 so badly, the radiator cap went below ground level!
We ended up with a wrecker, a Cat 966C loader (170HP and 15 tonnes), and a Centurion, all attached to the D7, to extract it!
Once the D7 started moving, the Centurion just took over, and left the wrecker and the 966C behind!
You should have seen the size of the hole left behind when the D7 was finally out! LOL
The Vietnamese are probably still using it as a waterhole! LOL
Mt Beauty? Isn't that above the snowline?? LOL
Spent a week staying in Wangaratta in early July, and that was plenty cold enough for me!!
Couldn't imagine what Winters are like in the Alpine country! Just thinking about it, gives me the shivers! LOL
Cheers, Ron.
FollowupID: 865863
Follow Up By: vk1dx - Thursday, Mar 03, 2016 at 10:23
It's cold enough at Mt Beauty when you are almost starkers. We were stuck up around the Kiewa Scheme works on the Bogong High Plain. Not in Beauty.
Spent some time (nashos) with 7fdsqn and 24constructionsqn before going to sigs. Don't tell me you drove tunzaguts.
I know the 966. Was doing driver and recovery stuff at 7FDWKSP, RAEME got plenty of time on most of their plant when on exercises. I had to get a licence for all their plant anyway. So . . . Good times.
FollowupID: 865864
Follow Up By: Ron N - Thursday, Mar 03, 2016 at 11:33
No, never drove tunzaguts, but I must have driven nearly everything else! Qualified on motor scrapers and dozers, but I drove loaders, forklifts, graders, rollers, water trucks, dump trucks, and virtually anything with an engine in it - as well as scrapers and dozers.
Built heaps of roads and a few bridges, operated quarries and crushers - hauled sand off the beach at Long Hai - whilst watching the U.S. Phantoms bomb the VC only a couple of kays away in the hills!
Licencing didn't matter in 'Nam, if you could show you knew how to drive it, you got a job driving it!
Of course, I'd been driving most equipment before I was called up, the Green Machine training was just refresher stuff.
As you can see, I was with the Land Clearing Team with 4 x D8's. Spent 3 mths with them.
What a mongrel of a job. Mud and dust - massive bomb craters that just swallowed D8's - scorpions, centipedes a foot long, monkeys, snakes, rats - they all joined you in the cab!
I once had a monstrous rat fall out of the canopy and run along the bonnet towards me - then it jumped straight off the bonnet, into my lap! Did some fancy dancing about then, I can tell you!
Then there were the mortars, the RPG's and the mines to contend with, as well.
We had one lucky escape when the VC dropped mortars on us - one hit the rounded top of an oxy-acetylene bottle, and bounced off and fell flat in the mud alongside the oxy bottle, without going off!
Best job I had was unloading the Jeparit in Vung Tau. The Vietnamese semis were so broken down, we had to push them up the hill into the yard at Vungers with the Case W7 forklifts!
The Cases were terrors, they had the hydraulic tank mounted right in front of the operator.
Work them hard on a hot day and the hydraulic oil would heat up and expand and blow out the tank breather, and cover you with oil! Oh, those fun days!
Wish I'd taken more photos!
Cheers, Ron.
FollowupID: 865869
Follow Up By: vk1dx - Thursday, Mar 03, 2016 at 12:30
No SVN with RAEME for me. Was with 104/110 Sigs when OS. I would have rather been with RAE myself. My job scared the be-whats-its out of me. Too late - sent me to Saigon for a break and never left there.
Who were you with?
PS Getting a little BIG little off topic Ron. Good to chant anyway. Catchya
Happier times - "up north".
FollowupID: 865877
Follow Up By: Ron N - Thursday, Mar 03, 2016 at 13:36
Phil, I was with 17 Construction Sqdn. It was good doing constructive work, but dodging the explosives was the tricky part.
We lost a lot of equipment, and a lot of blokes were hurt and a few killed.
A little Tassie mate, Ivan Ballard (deceased all too soon a few years ago) has sent all his pics of our operations to the AWM.
Here's a link to all his pics.
Sapper Ivan Ballard's photos of 17 Construction Sqdn
Here's a bunch of us having lunch on the rebuild of Route 2. It was some dumb corporals idea (not mine) to combine all the tins in the ration pack into a dogs breakfast for lunch!
I know all the blokes in the photo - the only bloke wearing a shirt is Mickey Wighton, he was a blackfella from Condobolin, he ended up becoming a high-level fat-cat in Canberra! LOL
Sappers at lunch on the road
Rode in the passenger seat of this F5 tipper to work for 3 weeks - and about 2 or 3 days after I changed jobs for Christmas, and stopped riding in that seat, my mate Peter Bates ran over a 10lb satchel charge! - with the passenger side front wheel!
This was on 27/12/70, I think - we were working the quarry at NDP Garth, it was real Noggie country, had a lot of really violent contacts all around us.
Peter Bates survived with blast injuries, he was medevacced on 28/12/70 and I never saw him again.
They eventually found his rifle more than 200M away!
Peter Bates tipper after mine blast
Close-up of Peter Bates tipper cabin
Cheers, Ron.
FollowupID: 865883
Follow Up By: vk1dx - Thursday, Mar 03, 2016 at 14:26
Luckily you chose "other means" instead of the Mk iV. We had an M113A1 at 7WKSP of which I was one of two drivers. Yep, Stood in as a mechanic for a couple of exercises.
Did you ever meet a Sapper Denis Lowe?. Spent time at 7FD with him and chasing waves. Lost track when I went to Sigs. We also had a couple of Mickey Wighton's mob with us in SVN. Lots of time for them. Worked their guts out. I always knew if I gave them a job it would be done and properly. Much reliable that one or two of my mob that I still know.
Take care but I think that we are way off topic mate. may catch up one day.
FollowupID: 865888
Follow Up By: Ron N - Thursday, Mar 03, 2016 at 14:34
Phil - No, didn't come across any Denis Lowe. Yes, we're definitely off-topic.
Yes, maybe we will catch up one day. Age is catching up with all of us first and fast, though.
Went to slightly edit my previous post - and you posted in the meantime, and that stopped my edit, and wiped out all my photo links.
Here's the photo links again, for the curious ...
Sapper Ivan Ballard's pics of 17 Construction
Cheers, Ron.
FollowupID: 865890
Reply By: axle - Wednesday, Mar 02, 2016 at 17:28
Two safety issues there straight away!, the guy standing beside the machine and beside that wire rope.! if that broke at the winch end he would more than likely be killed. the other issue putting a bar under the track to feed it on the top roller is a practical way to get it on, but highly dangerous if the track grabs the bar, should have two guys on that.
Cheers Axle.
AnswerID: 596865
Follow Up By: Ron N - Wednesday, Mar 02, 2016 at 17:54
We've fed dozer track on using that method, since dozers were invented - but they've got winches around them galore - they could have winched the track back on by pulling it over the top of the top rollers from the front.
Tracks roll on so easily using that technique, it doesn't take a lot of power.
Don't see any of them wearing gloves! They must be one tough lot of GI's! LOL
Anytime I work with Steel Wire Rope, gloves are a total necessity!
Saves a lot of missing skin and pinched fingers!!
Cheers, Ron.
FollowupID: 865825
