4wd picture
Submitted: Wednesday, May 26, 2004 at 18:24
ThreadID: 13182 Views:1814 Replies:5 FollowUps:1
hi
just got a 93 nh pajero 7 seater gls auto could any one tell me if the 4wd picture on the dash have the 2 rear wheels be alight in 2wd as mine does not.
Reply By: Lone Wolf - Wednesday, May 26, 2004 at 19:54
If it is "Super Select" , yes, the rears should always be on, although mine are a little dim now compared to the front ones. In the centre you may have an orange light fot the centre diff lock as well.
AnswerID: 60291
Reply By: GrantWA - Wednesday, May 26, 2004 at 21:41
Cluffy, I have a 94 NJ and yep the rear lights should be on in 2wd. Try the forum at Pajero Club. Someone there may have had a similar problem. The forum is down for maintenance though at the moment.
AnswerID: 60328
Reply By: MrBitchi - Thursday, May 27, 2004 at 08:14
Hi Cluffy,
Had a 92 model and yes the rear 2 lights shold be on. However, after many miles of corrugated inland roads mine ceased to work. Super select worked fine, just the dash lights went out......
Probably a blown bulb or bad contact.
JM
AnswerID: 60379
Reply By: cluffy - Thursday, May 27, 2004 at 08:54
thanks
looks like a bit more checking involed
cluffy
AnswerID: 60381
Reply By: vegie - Thursday, May 27, 2004 at 15:50
I've got a 91 NH with Super Select. The bottom two bulbs used to work and went out one by one. It was a fairly simple globe replacement.
AnswerID: 60452
Follow Up By: cluffy - Saturday, May 29, 2004 at 15:24
thanks lads for your response it is amazing what 2 globes can do
once again thanks
cluffy
FollowupID: 322331
