Exploroz Traveller app
Submitted: Monday, Aug 08, 2016 at 19:31
ThreadID: 133176 Views:2950 Replies:3 FollowUps:2
The Exploroz Traveller app works great, does everything I need. Only one thing, I'm not sure how to change. When tracking, the track takes long intervals between logging, creating straight lines rather than following the actual road/track travelled. Possibly a simple change to a setting.
Can anyone help out with this ?
Reply By: ExplorOz Team - Michelle - Tuesday, Aug 09, 2016 at 14:35
David says this is part of the work-around problem we encountered to try to make the app work with versions lower than V5 Android where he had to set a fixed timer - I think it's 1minute. This is only an issue for pre-Version 5 Android. Is 1minute really showing straight lines on the map? Assuming you are talking about Track Logging, not snail trail?
Michelle Martin
Marketing & Customer Support
AnswerID: 603230
Reply By: Member-George (WA) - Tuesday, Aug 09, 2016 at 15:36
Hi Michelle, Sorry, I should have been clearer. It is the Snail Trail but also logging when I look at my completed track recorded. My Android version is 5.0.1
AnswerID: 603232
Follow Up By: ExplorOz Team - Michelle - Tuesday, Aug 09, 2016 at 18:26
Ok so go to Settings - Advanced - Geolocations Setting - and make location update interval 5000, the fastest updated location interval to 10,000, and distance filter can be either 20 or 50 (what is it now?) - can you send us a screen shot to show us how straight the lines are? David doesn't think its these settings and could be a dodgy GPS but let's go with the setting changes first and see.
Michelle Martin
FollowupID: 872893
Follow Up By: Member-George (WA) - Tuesday, Aug 09, 2016 at 21:35
Hi Michelle, My current settings are, Location update 1000, Fastest update interval 1000, Distance filter 50.
I have now changed Location update to 5000, Fastest location update to 10000. I will leave the filter at 50.
I will be going on a short trip next Sunday and see what difference the changes make.
I will also send you a screen shot after Sunday.
Thanks for your help
FollowupID: 872902
