attaching Velcro to PVC canopy
Submitted: Wednesday, Sep 07, 2016 at 23:54
ThreadID: 133397 Views:8307 Replies:5 FollowUps:4
Hi, I have insect screens to go on a cage/box trailer used for camping. The screens are edges with flexible PVC material, & I want to attach it when necessary to the trailer with Velcro. The adhesive Velcro is sticking to the steel no worries, though it is coming off the PVC. Is there any sort of adhesive I could add to the Velcro to stick it to the PVC? I'm thinking that a flexible type rather than rigid will be the most likely to work. Regards, Mike :-)
Reply By: PhilD - Thursday, Sep 08, 2016 at 00:03
Have you considered sewing the Velcro onto the PVC?
AnswerID: 604205
Follow Up By: Cybermike - Thursday, Sep 08, 2016 at 00:09
Yes Phil - I did consider sewing though I wanted to take the easy way out so I bought 20m of the sticky stuff. Which makes me think of a heavy-duty stapler...
FollowupID: 873927
Follow Up By: Malcom M - Thursday, Sep 08, 2016 at 07:18
The 'sticky stuff' will fall off after an hour or so in the summer sun so you really need to sew it.
Same problem on the metal side so you'll need to rethink that attachment.
FollowupID: 873932
Follow Up By: Member - cherrywipe - Thursday, Sep 08, 2016 at 07:31
Maybe try Sikaflex glue in spray can. Do away with the sticky back tape and use non sticky. Or Bear gel in tube or can.
FollowupID: 873934
Follow Up By: Member - John and Val - Thursday, Sep 08, 2016 at 07:48
Forget velcro. Go to a printer and get some of the flexible magnetic stuff that fridge magnets and car door signs are made out of. Cut into strips about 2cm wide and use silastic or similar to glue it around the edges of your screens. We have screens for the front windows of our Troopy and this method works well, although the screens are best stored flat rather than rolled up.
Val.
J and V
- Albert Einstein
FollowupID: 873935
Reply By: The Bantam - Thursday, Sep 08, 2016 at 10:04
As an ex Velcro distributor, I can tell you there should be a velcro product to do the job.
If you baught Velcro ... genuine Velcro product ...... the standard adhesive is 072, this is their general purpose adhesive and probably won't work well on PVC or Vinyl ...... it is not water or temperature tolerant
There is an adhesive compatability chart for the various velcro adhesives that ..... a few years ago covered 5 different types of adhesive that velcro imported at the time.
074 grade adhesive has a higher temperature tollerance and is more compatable with PVC and Vinyl. ( not sure if 074 is currently available in Australia) ( I'm saving my personal stash) this product was intended for upholstry work.
074 was a great product .... my understanding is that Velcro Australia where having too many complaints because people failed to properly consider substrate compatability, failed to prepare surfaces and failed to understand the limitations of the product. ... so they stopped bringing it in .... that may have changed.
Of you realy want it to stick, what you want is heat and solvent activated ( cant remember the number) ....... this product is not sticky off the roll ...... it is either heat activated with an RF wand or is swabbed with one of the specified solvents, this softens and activates the adhesive ...... use the right solvent for your substrate any it softens the plastic substrate and keys into it.
Get a good bond with this stuff and it ain't comming off any time soon.
One of the problems with PVC and Vinyl is it contains plasticisers to make it soft and flexible..... these plasticisers leach out thru the life of the material and cause most adhesives problems.
here is something that might work .....( bear in mind standard adhesive is not water or heat tolerant)
Clean the area you are trying to bond to well with white spirit ( that is white spirit not metho) then mask up with masking tape and apply a thin coat of regular solvent bassed contact cement ( sprayable/ brushable adhesive) .... let it dry , remove the masking and apply the hook/loop tape.
If you are buying non-genuine product the adhesives are often very poor.
you will not get any commercially available adhesive to bond to normal sew on hook /loop tape ....... the adhesive products are primed with a proprietary substance to make the adhesive stick.
hope this helps
AnswerID: 604212
Reply By: steved58 - Thursday, Sep 08, 2016 at 11:38
I have noticed most comercial applications using velcro sew it on the pvc Then have a rope track on the metal that the mating velcro goes into the mating velcro has a rope sewn in I think this is probably one of the more garanteed ways of fixing it but will take some effort
Cheers Steve
AnswerID: 604213
Reply By: Member - ACD 1 - Thursday, Sep 08, 2016 at 15:42
I have used sika flex 227 to stick 50mm Velcro onto my trailer/awning to attach my batwing awning.
Just make sure you clean the area well with prep wash or similar to remove grease. Mask the area with tape that you want to stick the Velcro too. Squeeze out the sika and spread out evenly. Lay Velcro on top of Kia and gently press it down (so you don't squeeze out the sika and make a mess) leave for 24 to 48 hours to cure.
Just make sure you think it through and lay it in the right place - once it cures you will never move it.
Anthony
AnswerID: 604218
Reply By: Cybermike - Tuesday, Sep 20, 2016 at 14:26
Thanks everyone for all these options. The original idea the upholsterer was working to was removable screens to do away with them when travelling & to let the air go more freely through the cage to reduce wind resistance. However, now I'm thinking of more importance is to be able to sleep without insects, so I'll take the trailer back to him & suggest these options. Even if the screens have to be more permanent - which means he'll probably want to sail track them in. Cheers.
AnswerID: 604529
