Brian with 3 litre Patrol and Ox winch
Submitted: Tuesday, Jun 01, 2004 at 00:12
ThreadID: 13350 Views:2060 Replies:3 FollowUps:2
BRIAN if your out there I have a question about your Ox Winch cheers from Paul
Reply By: brian - Tuesday, Jun 01, 2004 at 09:16
Paul,i am here how can i help,Brian
AnswerID: 61135
Follow Up By: Gerk - Tuesday, Jun 01, 2004 at 12:45
Thanks for the reply Brian. I have the Ox in hand if youll pardon the pun. It has come with 6 hoses (2 long about 750) 4 about 400 (hoses don't have any eye ends for pump/box think they are a universal type and I presume i'm short the 2 male/male connectors that screw into the pump) Did you have tjm fit yours and are the connectors behind the bar except for the line to the pump and steering box (mine also has the dump valve so need to run power and switch to the dash) Is the control lever on the end of the winch toward the passenger side and the cable comes out the bottom of the drum. Was there a reason for the arb over the tjm bar.
Don't have a bar to mount it in yet, the factoy alloy bar looks too hard to modify. many thanks from Paul P.S. is there a way to contact you other than the forum?
FollowupID: 322737
Reply By: Bonz (Vic) - Tuesday, Jun 01, 2004 at 11:18
well what was the question?
AnswerID: 61151
Follow Up By: Member - Roachie- Tuesday, Jun 01, 2004 at 12:01
I just phoned Paul at work to let him know he's received a response. He'll probably get onto a puter either at lunch time or after work.
FollowupID: 322733
Reply By: brian - Tuesday, Jun 01, 2004 at 18:12
Paul,I had mine fitted by south coast 4wd to ARB steel bar,I just preferred ARB over TJM just personal preferance.The levers are on drivers side not passengers side.The opening in arb bar for your arm to activate levers is just too narrow for your arm needs to be enlarged.Also the position of the levers in the diagram on the winch is incorrect.I do not have the bypass but it works well,slower than electric but less problems and more powerful
i can be contacted by email on fitzgerald@speedlink.com.au will also give phone number if you want
AnswerID: 61226
