Sunday, Oct 30, 2016 at 16:54
Annie,
If I have got a handle on this so far, you are running a fridge and a freezer which between them you state draw, in round figures 2 amps @ 240 volts????
You also have a couple of Ipads which I assume get charged as required, maybe a couple of times a day.
Then there is the DVD which I assume gets a run as required but maybe not continuously.
All of this is running on 240 volts????
What I am unclear on is how the 150 watt solar panel fits into the picture. I would imagine you are charging a 12 volt battery?????
So are you running an inverter somewhere in here to also supply 240 volts???
If this is the case remember that a 150 watt rated sola panel is only capable of providing it's rated ability under perfect basically laboratory conditions.
Just as a comparison I use my Honda 2.0 during extended power outages. It runs a 400 lt fridge freezer and a 300 lt chest type freezer, along with a few lights and barely raises a sweat. Would 1.0 Honda or Yamaha do it?? No idea, never tried, but we are talking about domestic units much much larger than what you have.
Going on the figures you have supplied the 2 fridge freezer units need around 500 watts, I think. The 1.0 Honda has an intermittent rating of 1000 watts and a continuous rating around 800 watts from memory. I would imagine the Yamaha would be similar. Going on that, you should be able to run them together. Starting together may be problematical. No idea without trying.
As for charging a couple of Ipads and using a DVD I would doubt the power requirements would be all that big but once again without seeing their ratings, I have no idea.
Pop
875276
