Hilux engine swap
Submitted: Thursday, Nov 03, 2016 at 21:55
ThreadID: 133713 Views:8209 Replies:5 FollowUps:1
hi all
i have a 99 hilux with a tired 2.7 petrol
i have an opportunity at get a 015l turbo diesel with everything needed to do a swap
my question is are the chassis engine mount pedestal positions the same petrol and diesel
4b's are't side by side so i cant check it myself
thanks in advance
Michael
Reply By: The Bantam - Friday, Nov 04, 2016 at 00:12
the chassi and engine mounts are pretty much consistent across the range in the same year model.
The biggest problems you will have is pretty much everything under the bonnet is on a different side and most of the plumbing is different.
If it is a electronic fuel injected original vehicle or new engine you will need the entire front harness and dash.
Petrol to diesel conversion in a post EFI vehicle is a substantial undertaking ....... what you realy need is an entire front cut.
AnswerID: 605653
Reply By: Dean K3 - Friday, Nov 04, 2016 at 12:42
I'd suggest a v6 engine conversion from commodore be a better option accept need engineers certificate (unless hilux comes with a v6 engine as std think some did one stage).
be a massive change over project to convert to diesel fuel lines tank all need to be replaced.
dellow or marks 4wd adaptors woudl have necessary engine mount kits etc
AnswerID: 605670
Reply By: swampy - Saturday, Nov 05, 2016 at 07:27
hi
A complete wreck of a diesel version is required
Far easier conversion that way .
Little of the petrol version will be usefull
mounts ,engine , eng accessories , complete wiring loom ,fuel lines / tank , clutch and maybe g/box , rear diff ratio, front springs/ torsion bars ,dash board / gauge cluster
glow plug system , air cleaner assem. , exhaust etc etc etc
tomo
AnswerID: 605682
Reply By: axle - Saturday, Nov 05, 2016 at 20:55
G/Day Michael, Why not rebuild the 2.7 petrol?..cheaper than going through all that exercise....My son inlaw has a 2.7lux that has done 580,000 km, never been touched!....In my opinion there the most reliable engine toyo has ever built...Forget about the the little extra fuel cost, you will never catch it up now.
Cheers Axle.
AnswerID: 605689
Follow Up By: The Bantam - Sunday, Nov 06, 2016 at 12:04
AND the 2.7 litre petrol will make more power than the turbo diesel ...... that is in factory form .... the rice rocket boys get silly amounts of power out of them.
FollowupID: 875447
Reply By: mountainman - Tuesday, Nov 08, 2016 at 11:46
My old work had a single cab 4x2, 2.7 petrol/gas.
on gas the thing absolutely FLEW
IT HAMMERED.
Get it rebuilt and put it on gas.
the performance difference was just INSANE
I LOOOVED driving it
AnswerID: 605749
