240v to 12v transducer
Submitted: Thursday, Jan 05, 2017 at 23:39
Member - Raymond J
Looking for the best place to get a 240v to 12v transducer to be able to run a Techniice car fridge. Thanks for any info
Regards Ray
Reply By: Member - DW Lennox Head(NSW) - Friday, Jan 06, 2017 at 04:15
Ray
I think you mean a transformer. I have several for my
portable fridges. Jaycar would be a good place to possibly get one.
https://www.jaycar.com.au/12vdc-7-5a-switchmode-power-supply-mains-to-cigarette-lighter-socket/p/MP3575
A transducer is an electronic device that converts energy from one form to another. Common examples include microphones, loudspeakers, thermometers, position and pressure sensors, and antenna.
Duncan
607258
Follow Up By: Kazza055 - Friday, Jan 06, 2017 at 09:26
You might want to get Jaycar to plug this in and run it, they have a small fan and can be very noisy.
876976
Follow Up By: Member - Raymond J - Friday, Jan 06, 2017 at 19:15
Hi Duncan
After all the info went to jaycar and got a transformer, it was for the mates fridge and thanks again.
Regards Ray.
877010
Reply By: Denis H - Friday, Jan 06, 2017 at 07:42
Hi Raymond,
As per Duncan but before you start looking you need to know how much power (Watts) the Fridge will use on 12VDC. This figure maybe given in 'Amp's' which can be high for non compressor Fridges.
Denis
607263
Follow Up By: Member - Raymond J - Friday, Jan 06, 2017 at 19:18
Hi Denis,
As you wrote, had to check the Amps to get the write one. Di so and thanks again.
Regards Ray.
877011
Reply By: Allan B (Member, SunCoast) - Friday, Jan 06, 2017 at 10:18
I thought Techniice fridges had the capability to directly accept either 240vac or 12vdc.
The following is from their website......
"Power Supply Options:
With our in built 12v / 24v and 240v connections, you can use your fridge / freezer when connected to mains or when mobile in most vehicles including trucks, 4x4’s and boats making it a very versatile option for keeping your product cold. Both connections can be plugged in simultaneously and can interchange depending on the available source."
Or perhaps that is only the current models. Maybe earlier models were 12vdc only?
However, if that is not the case, a good solution is to use a battery charger that has the "SUPPLY" option of a constant 13.6 volt output. This way you would have the benefit of having a multi-stage battery charger as
well as a fridge power supply. My Waeco fridge is running at the moment in my workshop from such an arrangement.
A Ctek MXS-10 or -15 is one such charger.
Not the cheapest option however.
Depending on current draw, a cheap option is to use an external power supply from a discarded laptop computer. Some of these provided 12vdc at up to 7 Amps and can be found at secondhand shops, computer repair shops and council recycle depots
607268
Follow Up By: Member - Raymond J - Friday, Jan 06, 2017 at 19:28
Hi ALLAN,
The mate and went to jaycar and got a transformer to suit the fridge. His only had the 12 and 24 options so he went with that but thanks for the info on the battery charger. I used to breed finches in large aviaries and used to run light from car tail lights through a battery charger to attract insects for the finches to feed their
young. Thanks again.
Regards Ray.
877013
