best winch - seems it been a while since this topic has been raised
Submitted: Wednesday, Jan 11, 2017 at 20:22
Member - Croaky
I'd like a 12,000 / 12,500 LB winch as my vehicle will be around 4,000kg when fully loaded and I'll also have 2200kg camper at times.
I'd like synthetic rope and wireless for easy of use when pulling boat out;
I've been looking at;
Warn - expensive with possible warranty issue's for
water ingress, even with waterproof models
T-Max - not sure about wireless model, hard to find info on this one
VRS - seem OK, good report on 4x4 Aust
Ironman - not sure about heating issue with drum break
Runva - not sure about wireless and quality
I'm interested in recommendations from experience
Reply By: pop2jocem - Thursday, Jan 12, 2017 at 01:14
G'day Croaky,
First up I am no ones expert on
winches but here goes what little I have experienced.
I have a T Max 10,000 non wireless just the plug in harness.
From what I can see the build quality appears OK. As far as usage goes
mine has only had 2 runs. Once to make sure it actually worked and to bed the steel rope in properly by pulling my Cruiser up a bit of a slope. The other to pull another bloke out of a soft sand patch. It seemed to handle that OK even though he had
well and truly buried it.
AFAIK the synthetic rope heating problem is only with the brake mechanism inside the drum, but you seem to be onto that one anyway.If I had occasion to replace what I've got I reckon I would go wireless remote but I'm not too sure about the synthetic rope although there is apparently quite a substantial weight saving. I guess if you are going to pull a boat out of the
water synthetic would make sense.
Pop
607484
Follow Up By: Member - Croaky - Thursday, Jan 12, 2017 at 06:21
Thanks Pop,
From what I can gather there are a few good options to Warn these days and about 1/2 the price, from Australian companies.
Albeit some parts of
winches made in china.
I'll be going with the few that have IP67 and IP68 full
water proofing and some even cover warranty if winch is submersed under
water.
(by accounts if you tell Warn it has been fully submerged it will probably void warranty on a very expensive winch, if you read the fine print)
877184
Reply By: Baz - The Landy - Thursday, Jan 12, 2017 at 06:59
Superwinch is another to consider?
Cheers, Baz - The Landy
607485
Reply By: Crusier 91 - Thursday, Jan 12, 2017 at 08:46
Hi Croaky
I have a 7 year old remote Ironman 12000lb with rope, purchased second hand 5 years ago from a 4wd instructor.
Recovered 2 fully loaded landcruisers out of wet beach sand up to their bellies on 2 seperate occassions, though a lot of digging, 2 other vehicles connected to my rear for
anchorage and a few hours of stress from tides, we got them out AOK.
The way i was taught to operate a winch is to take as much stress of the winch as possible, give it a rest after every 30 seconds of use for 15 seconds.
The last time i used the winch was 2 years ago, pulled a few smaller stumps out of the garden.
I only use it as a last line of defence these days, max tracks, tyre pressures, snatching and driving knowledge has pretty much put the winch on permanent holidays .
I can not stress enough the benefit of having a remote with a good range and a few spare double A's.
607488
Reply By: Malcom M - Thursday, Jan 12, 2017 at 09:39
I have a Premier and a Tigerz Although the Premier is several times the price, both have been brilliant.
Everyone is going to recommend what they have so you aren't really going to learn much.
I suggest you get a list of the names that members reckon are good and then Google them all for fault reports.
All
winches are wonderful till they crap out when needed most...
607491
Reply By: Batt's - Thursday, Jan 12, 2017 at 10:56
My old 1999 model Warn XD9000 is still fine but if your after waterproof maybe one of these is for you they have a 5yr warranty how does that compare to the others
https://www.sherpa4x4.com.au/
607495
Reply By: john m85 - Friday, Jan 13, 2017 at 16:42
I have a 8ooolb warn 30 years old not a spec of trouble
607524
Reply By: Member - Munji - Friday, Jan 13, 2017 at 18:55
Try Terrain Tamer - they like most others import theirs from China.
What they do is pull the
winches apart, check all components and replace what is suspect, new load of grease before they sell them.
They offer as good a warranty as anyone else with similar IP ratings
Remember IP is not
water proof.
Good luck
607532
Reply By: Member - Croaky - Saturday, Jan 14, 2017 at 12:39
Thanks all for feedback, seems everyone is pretty much happy with what they have.
Remember my criteria was;
- Around 12000LB
- Synthetic rope
- At least IP67
water and dust rating
- A good wireless option
So that rules out a lot of
winches mentioned.
I've also ruled out the el-chepo under $600 options which there are many.
The top of the pile IMO is;
- Warn Zeon premium and platinum - top dollar top
winches
Then I've dropped straight down to the $800 to $1600 dollar range, all Australian design and specification but made in china like the majority of
winches;
T-Max
VRS
Runva
and a stand out as far as I can see is a relatively new contender the Carbon Winch RRP $849, 12000LB, full IP68 rating and light at under 20kg (23.45KG total weigh all components fitted).
I'll keep you posted on my final decision, hopefully I'll decide early next week.
regards
Croaky
607552
Follow Up By: Shaker - Saturday, Jan 14, 2017 at 13:52
Did you check out the link to Sherpa
winches? If you did I would be interested to know why you discounted them.
877247
Reply By: Batt's - Saturday, Jan 14, 2017 at 13:15
Have you seen the punishment the 4x4 adventure team put their TJM
winches through and their pulling a lot more gear around than the average 4WDriver does. Yes we can't see what happens off camera but they seem to be putting the
winches through a torture test that most 4WDrivers would never encounter.
607553
Reply By: Frank P (NSW) - Saturday, Jan 14, 2017 at 16:44
Hi Croaky,
You mentioned that you were unsure of Runva's wireless and quality. I find it excellent. Good range and reliability.
I am not a big winch user so I cannot comment on long term reliability under frequent hard use. But it does work every time I give it its bi-monthly maintenance run :-)
I chose Runva after reading
this. You also may find that link useful, particularly in regard to warranty comparisons and
water ingress.
607561
Reply By: Member - Croaky - Monday, Jan 16, 2017 at 08:39
My apologies to those who thought this was a comprehensive post on winch recommendations for all, as, my post was to gather information for myself, to decide what winch to buy for new vehicle.
Again, I was after 12000LB plus
winches with at least IP67 rating with good remoted.
It seems that most of you are happy with the winch you have, albeit not fitting my criteria.
The link posted by Frank P is a comprehensive listing of 'Buy' and 'Walk' recommendations, primarily bases on warranty regarding
water and customer service, this is the link;
Winch 'Buy' or 'Walk'
There has been a lot of time spent on this link, and a lot of you wont' be happy with your
winches listed on the 'Walk' list, but remember this link is based on 'warranty' particularly in regards to
water and customer service.
Ken
607613
