Finch Fridge spare gas line part
Submitted: Monday, Jan 16, 2017 at 09:41
Linda T1
I have just gained an old finch fridge which has been passed down through family. It works perfectly but am needing a new gas line for it. I am lost on where to buy a new gas line for it. Can anyone help. I live in QLD.
Linda
Reply By: Sigmund - Monday, Jan 16, 2017 at 10:48
Can you remove it?
Maybe call a crowd like this one and see if they can make up a replacement.
http://www.caravangasman.com.au/
607623
Reply By: derraux - Monday, Jan 16, 2017 at 13:36
From memory the old finch Fridge was a 1/8bsp connection for the gas the easies way is to put a brass adaptor on the fridge from 1/8bsp female to 3/8sae male and buy a new regulator and hose and a 3/8sae is very easy hose to source, Gas components Australia have a place in QLD the fitting is a number 16 3/8 x 1/8 hope this helps.
Derek
607632
Follow Up By: Linda T1 - Monday, Jan 16, 2017 at 23:21
Thank you for that information. Very helpful, much appreciated
877330
Reply By: Shaker - Monday, Jan 16, 2017 at 14:26
You will find what you need at Supagas or BBQs Galore, take the fridge with you to avoid confusion.
607633
Follow Up By: Linda T1 - Tuesday, Jan 17, 2017 at 08:37
Thank you for your help will be looking into those stores.
877336
Reply By: Member - Mark C (QLD) - Monday, Jan 16, 2017 at 20:31
Mine is 34 years old and still going as a drinks fridge and also on gas for a friend as he builds a house in the bush and uses the fridge. I bought a new gas lead from BCF as they had a whole array of sizes to fit the thread.
607646
Follow Up By: Linda T1 - Tuesday, Jan 17, 2017 at 08:39
I will be going to a BCF this week, thank you for your help
877337
Reply By: Member - William B (The Shire) - Wednesday, Jan 18, 2017 at 08:55
Hi Linda T1,
I can not answer your question re the gas line.
I inherited a Finch from my Father and found that if you run it on gas it works fantastic.
On 12v it consumes a lot of power.
William
607701
