cigarette power panel setup
Submitted: Friday, Jul 07, 2017 at 16:43
Cybermike
Hi there,
I have one of the surface-mount types - Ridge Ryder brand - with a few variations of power outlets, voltmeter, & clock. All but the clock are working. The clock has both the usual pos & neg blade terminals on the back - plus a third one. Does this need to be connected up to pos or neg wire? Just thought I'd ask here before I took a 1 in 2 chance of frying the clock.
Also, is it possible to rotate the sockets in the panel? The clock & voltmeter need to be turned 180 degrees & I fear something's going to snap if I try anymore, & it's not the type with the lock position indicated on the front of the sockets.
Cheers.
Clock
Also,
Panel
Reply By: Kazza055 - Friday, Jul 07, 2017 at 18:01
My guess is that the clock should have three wires being Ground, Accessories and +12VDC which should be a permanent battery supply used to keep the clock running.
The bottom photo shows 2 fuses, one being the Acc supply and the other being permanent 12V.
612402
Reply By: The Bantam - Thursday, Jul 13, 2017 at 13:58
Good luck with the clock who knows without some documentation or labels on the back.
If the sockets have screw down securing rings on the back they can be rotated, but the clock and Voltmeter look to be moulded ... bad luck
612480
