Saturday, Sep 02, 2017 at 16:25
Johnnykluger "is the
solar power always charging while you are on the move to power the fridge? "
You can have it hooked up through some suitable connection to be charging as long as there is some light, but best to have the 2nd batter(ies) hooked up to charge from the vehicle when driving, the output from the vehicle alternator far exceeds what you'd get via solar (in a typical setup).
The fridge would be always running from the 2nd battery, the solar or vehicle charging keeps the battery up.
You can run vehicle charge form the car alternator via a VSR (voltage sensitive relay) for a very simple method, this suits me, or others with higher needs may us DC-DC type charging, or other newer / better tech.
883951
