Oil Recommendations
Submitted: Tuesday, Oct 31, 2017 at 17:26
ThreadID: 135813 Views:5489 Replies:9 FollowUps:16
I have a 1998 Hilux 3 litre dual cab 4×4. It has 560,000 km on the clock.
My question is should I use a thicker oil. I have always used semi synthetic oil 15w 30 simce new.
Reply By: Member - mark D18 - Tuesday, Oct 31, 2017 at 17:33
Robert
Keep doing what you are doing , but a 15/40 mineral oil (any name brand )would be fine as well .
Regular oil changes will keep most old diesels going .
AnswerID: 614669
Reply By: 9900Eagle - Tuesday, Oct 31, 2017 at 17:38
Rob, if it isn't using that oil stick with it. The only time you go to a heavier grade in your circumstance, is when starts to use oil. If you contact your oil manufacturer tech department, they will tell you the same thing.
AnswerID: 614670
Reply By: RMD - Tuesday, Oct 31, 2017 at 19:38
I don’t agree any name brand is ok. Some oils seal rings far better than others do. A poor oil will cause the oil to go black too early because it doesn’t seal the rings well enough. I don’t know what you use but Caltex Delo or Mobil Delvac MX is better than most others.
A full synthetic oil may seal better than a normal mineral oil does, but the cost may not warrant it’s use.
I wouldn’t use a thicker oil unless trying to control oil use.
AnswerID: 614674
Follow Up By: Member - mark D18 - Tuesday, Oct 31, 2017 at 20:28
Rmd
So why do you recommend those two brands only , are you saying all other brands are not satisfactory .
All the other name brands are name brands because of the protection they have offered for many years in many different motors .
FollowupID: 885314
Follow Up By: RMD - Tuesday, Oct 31, 2017 at 22:42
G'day Mark
No, I wasn't saying the other oils commonly on offer are not satisfactory, Satisfactory is to me, means sort of good enough but not above the pack.
I consider Castrol, Valvoline, Penrite, and other heavily promoted oils just aren't as good or perform as well as the two mentioned.
A while back, approx 2 years ago I had quite a lot of correspondence with Hilux owners who had oil burning/use problems. Their oil also went black too soon after a service change.
Some of them changed to either Castrol Delo in appropriate specs/viscosity and or Mobil Delvac MX. They reported back to me their oil use had reduced and the rings must have sealed better than before because they noticed had less blowby and subsequent less caontamination rate of carbon into the sump oil.
I have found similar performance but in different Toyota engines.
I never use those advertised oils, they must sell less because they have to advertise them.
It is interesting what transport companies use, it isn't those lesser oils, why would that be?
FollowupID: 885317
Follow Up By: Member - Tony H (touring oz) - Wednesday, Nov 01, 2017 at 00:30
Mark,
What a crock of excrement !!!!!!
Personally, I don't use BP/Castrol (one and the same) but your doubting its quality,
& you also bag Penrite an Aussie product.....just out of passing Mark what oil was in the winning car (Holden) at Bathurst this year?
Cheers & stay safe
FollowupID: 885324
Follow Up By: bellony - Wednesday, Nov 01, 2017 at 00:59
Just because a race car has a sticker on the side does not mean it is using that product.
Only the team really know what is being used, and even then probably only a couple of staff members know the truth.
FollowupID: 885326
Follow Up By: RMD - Wednesday, Nov 01, 2017 at 07:53
Tony H
I suppose you believe P Brock used Mobil oil in his car, as mentioned above, the sticker on the door mean nothing.P Brock used NEO synthetic oil from USA in his cars for a long time. I Know who used to import it for him in 44gal drums, lots of them.
FollowupID: 885328
Follow Up By: The Bantam - Saturday, Nov 04, 2017 at 12:17
RIGHT
Lets talk about Diesel spec oils ..... and yes I have done quite a bit of research into the matter. over more than 5 years
The diesel spec oil market is very competitive ... heavy transport uses heaps of this stuff and yes the same stuff in the right spec goes in your 4wd.
Unless you get into the exotic top spec stuff from the US, the best value for money and performance is Mobil Devlac, Caltex Dello and and a couple of the Shell ( rimular and rotella from memory) products and there is very little to seperate them.
BP and that includes Valvoline ( their cheap brand ) and Castrol (their flagship brand) have been dragging their heels on everything for over a decade.
In this market Pennrite ( and the other boutique oil brands) simply does not compete well in the under 20 litre market.
In the last year or two there has been a shake up in the Diesel spec oil market and everybody has had to lift their game.
If you have a pre common rail diesel you are looking for a JASO DH1 rated oil .....
From memory even Castrol RX super is now JASO DH1 accredited ( it was not for a long time), the word is the old RX super has been re-branded down range.
There are some issues raised with the more modern formulars and what additives are permitted in the later specs ..... there are arguments that, where permitted DH1 is a better oil than DH2 ( the common rail spec), because of the additive that are permitted and don't harm the DPF.
YES in this market the JASO spec is the one to go by.
ANY JASO DH1 rated oil will be fine for a pre-common rail diesel ... the spec and the market is so damn tight.
BUT the best value and performance is in the 3 mentioned , Mobil, Caltex and Shell.
Personally I run Caltex Dello 400 15w40 in my 03 diesel and pretty much everything I own right down to the ride on mower.
Most of these oils are "multi-fleet oils" which are specifically designed to run in the whole fleet diesel and petrol.
Start looking at the oil specs they comply with and it will open your eyes ..... then compare that with retail oils and you will be in for some surprises.
All the DH1 and above rated oils will be at least semi synthetic ...... it is not them being synthetic or not that matters it is the oil specs they comply with ... read up on the oil specs
Concern yourself with what oil spec is complied with and not what is written on the bottle or the advertising.
If you want to read up on these issues start with " bob is the oil guy"
When it comes to buy, whatever brand, buy where the truckies buy and 20 litre minimum.
Some of the truck stops do well, some of the diesel spares shops are worth a look.
Personally I buy from the Caltex fuel depot at Lytton ( not the refinery) .... they won't give you their best price over the phone.
For dello 400 you should be looking around the $120 ish for a 20 litre .... I buy 2 x 20 litres when I buy so my price might be out of date.
Bottom line is you can't go wrong with any JASO DH1 rated oil .... the market is so very competitive.
Think twice about running more exotic grades ... there are some arguments both ways
I hope this helps
cherrs
FollowupID: 885435
Reply By: Theo D - Tuesday, Oct 31, 2017 at 23:35
I too would thoroughly recommend Mobil Delvac MX or just plain Mobil Delvac in 15/40.
It has by far the best characteristics of any oil out there. Its detergents within the oil keep it insanely clean therefor keeping your engine clean.
But then again if its done 560K, its obviously been doing pretty well with whatever has been running through it!
AnswerID: 614677
Follow Up By: Member - Tony H (touring oz) - Wednesday, Nov 01, 2017 at 00:40
Theo,
Recommending/suggesting changing to a synthetic HIGH detergent oil in 'an engine' that has done 560,000k's on an unknown oil is crazy.
The high detergent will certainly clean the engine....(resulting in filthy oil in no time) ......including removing the carbon build up around the rings.....resulting in massive oil consumption in a relatively short period!!!.
Not trying to take anything away from Delvac as it is a great lubricant......if used continuously from new or a vehicle with low k's !
FollowupID: 885325
Follow Up By: Theo D - Wednesday, Nov 01, 2017 at 17:25
Like I said, if it's done 560K with no hiccups - maybe not touch it?!?!
But, if you were to change... I would still use Mobil Delvac.
I have used this in three of my diesel vehicles after using other oils (all of which at the time of change were over 250K) and the Delvac was coming out much cleaner at every 5K oil change. Absolutely zero change in oil consumption. It didn't make any noticeable change in power or performance, but my mechanic who does periodic work on one of my vehicles (a 3L zd30 Navara) commented on how clean it looked when changing the oil injector seals. He guessed exactly which oil I was using, too.
I have a family friend who is now using this oil in his 2H turbo 60 Series (which has done over 400K) and he can't speak highly enough of it.
Just my 2c worth.
FollowupID: 885333
Follow Up By: The Bantam - Saturday, Nov 04, 2017 at 12:32
removing carbon build up around rings in Diesels may not necessarily increase oil consumption.
carbon build up between the rings can be a cause of loss of compression and performance in Diesels.
Loss of compression in Diesels is a far bigger problem than oil consumption.
When my diesel first came to me it was a bit of a slug ..... a couple of hard runs and short oil changes and it was running a hell of a lot better and at over 300 000 the compression is still well within spec.
FollowupID: 885437
Reply By: bellony - Wednesday, Nov 01, 2017 at 01:01
If it has done that many km dont change a thing, its obviously in a happy place.
AnswerID: 614678
Reply By: pop2jocem - Wednesday, Nov 01, 2017 at 12:51
Robert,
Don't fall for the old "thicker is always better" when thinking engine oils.
The only time I would recommend going up a grade to maybe 15w 40 or such would be if you were spending most of your travel time in northern climes, towing a heavy load, or maybe if oil consumption is getting very high between oil changes.
As others have said, 560,000 ks is pretty good going. I would not change brands or oil type.
If you could see what oils racing cars use you might get a bit of a surprise how thin they are. Also how expensive. The thicker the oil the more power is robbed from the engine.
Pop
AnswerID: 614681
Follow Up By: Member - mark D18 - Wednesday, Nov 01, 2017 at 19:48
Pop
15w40 is one of the most common grade oils used in older 4x4 ,s . Comparing a racing car with the an old 3 litre Hilux is a long bow .
FollowupID: 885337
Follow Up By: pop2jocem - Wednesday, Nov 01, 2017 at 22:03
Mark,
I'm not trying to compare apples with oranges. Just making the point that thicker i.e. 15w-40 50 or whatever is not better in all cases.
The OP Robert has used a certain oil of a certain viscosity in whatever application he uses his vehicle for and now reports that he has achieved 560,000 ks.
I pointed out that whatever he is using seems to be working for him so why change now unless something has changed recently.
Pop
FollowupID: 885344
Follow Up By: The Bantam - Saturday, Nov 04, 2017 at 12:39
If you have your glovebox manual you will see a viscosity v temperature chart.
For anything we will encounter 15w40 is just fine.
I have heard several accounts of people putting 20w50 in Toyotas and getting an increase in oil consumption and smoke from the exhaust.
My understanding is that this is due to the head not draining fast enough at high RPM and oil going down the valve guides .
Thicker is not always better.
Remember much the lubrication system, particularly in the bottom end relies on oil pressure and not oil thickness.
The safest choice is to stay with the standard specified viscosity.
FollowupID: 885439
Reply By: swampy - Wednesday, Nov 01, 2017 at 20:42
hi
Hilux recommended diesel has been 15W/40 since Noah was a boy
Using a 10W / 30 ,
the 30 weight is for cooler temps and fuel economy
The reason u did not here of a 10w/40 is the oil could not stretch that far until additive packages improved eg semi synthetic / full synthetic.
A 20w/50 is to much for most engines on start up .
Synthetic oils do pour quicker for a given grade/weight of oil .
Mobil petrol and diesel oils have a lot of detergents .
I have had many a fleet of petrol engines and fewer diesels using Mobil mineral have high consumption issues .
Castrol had it with GTX when it first came out real bad .
Mobil synthetic is good oil at reasonable cost .
Caution with full syntheticMobil and Castrol went to court and Mobil lost .
All of a sudden Castrol had a new range of oils .
CASTROL IS GARBAGE
The definition of full synthetic oil has become watered down .
Becarefull of the oil u buy in OZZY overpriced low technology passed off as premium .
AnswerID: 614690
Follow Up By: RMD - Wednesday, Nov 01, 2017 at 20:53
An engine should start ok on 20w50 as it is only 20 viscosity when cold and NOT 50 as some seem to think. 50 means it only thins to what 50 would thin down to when it is hot. Therefore it is thicker when hot than a 20w40 and is more parasitic drag on the engine internals.
I agree, Castrol is rubbish and most other “dumped “ oils in Oz are too.
Many oils are spec’d up on the label but don’t do the job but are sold as best ever by unprincipled companies.
FollowupID: 885341
Follow Up By: swampy - Thursday, Nov 02, 2017 at 00:00
hi
RMD
Agreed on how oil system works I do underatand how it works but eg 20w-50 takes longer to get oil pressure upon start up . I suspect that's the pour-ability of the mineral oil . Synthetic oil does is not effected as severe . At least that's what I have experienced.
There is an oil test that's carried out by oil makers just cannot remember its name .
Evidence is when u have to run engines with valve covers removed, oil when as above takes a while to get around fully.
My advise to people is try different oil combos and u would be surprised .
Some oils [mineral] take along time to spread internally in an engine ,you would be surprised !! Typically 20w/50 .
As we all know now is oil technology has improved greatly so for use in older engines that's great .
For later tight clearance ,turbo [temperature] and even diesel , plus longer oil changes all place big demands on your oil .
FollowupID: 885352
Follow Up By: andrew t - Monday, Nov 20, 2017 at 12:25
on what basis are we saying castrol is rubbish, does it not meet the same standards as other oils???? or is that just a personal opinion that castrol is rubbish. i used castrol rx super in my old troopy happily hit 747,000 odd km before the rust took over the body nothing wrong with castrol in my opinion.
FollowupID: 885907
Follow Up By: The Bantam - Tuesday, Nov 28, 2017 at 14:36
Absolutely everything manufactured by BP and that includes Castrol and Valvoline has been behind the game for some time ...... except some of their custom made for purpose products.
Castrol has been more about advertising and less about achieving performance for a very long time .
Look at any of the independent oil reviews and the BP products lag the field.
Yes you can look at the multiple standards that the particular oils are certified.
This diesel spec market is very competitive and very well scrutinised and independently reviewed.
Some of the smaller oil companies may make competive or superiour products in other areas, but in the main stream market and in diesel spec oils ... BP products lag the field.
FollowupID: 886137
Reply By: Malcom M - Thursday, Nov 02, 2017 at 06:23
Consider also if you have a turbo, a thicker oil is likely to affect that.
AnswerID: 614702
Reply By: Member - Phil G (SA) - Thursday, Nov 02, 2017 at 21:11
Never seen a 15w30 oil. I suspect you mean 15w40. If so just keep using any 15w40 diesel oil.
AnswerID: 614719
