Amps Volts and Watts
Submitted: Sunday, Feb 04, 2018 at 15:51
Robert E4
I have just purchased a 2017 Pajero and the power point at the back where a fridge can be plugged in has a stamp on the cover saying its 120 Watts, will that be sufficient power to run an 80 lt fridge freezer, or is that only 10Amp and I should upgrade it to 15Amp..
all help appreciated.
Rob
Reply By: Allan B (Sunshine Coast) - Sunday, Feb 04, 2018 at 16:05
Yes Robert, that is 10 Amps max current draw at a nominal 12 volts.
But it is quite possible that if you were to draw 10 Amps from it the voltage at the power point would drop by a volt or so.
The average fridge only draws around 2 Amps so it may be OK. We will probably hear from some Pajero owners who can comment on it performing with their fridge.
616659
Reply By: Gronk - Sunday, Feb 04, 2018 at 16:27
In theory it should work, but in practise it may not. The size of the factory wiring may be rated to carry 10A, but voltage drop, as mentioned, may see your fridge cut out due to undervoltage.
If it was my 4wd, I'd run a dedicated twin cable and merit socket to the rear......8mm2 would be sufficient !
Nothing worse than hot beer, when $100 in cable and socket etc will assure you of no problems.
616660
Reply By: Gazza11 - Sunday, Feb 04, 2018 at 16:36
I think it highly unlikely that any compressor fridge would draw 10A continuously, more likely 2-3 amps but maybe a spike of 10A for a millisecond at compressor start up which shouldn't blow the fuse or
cook the wiring!
Gazza
616661
Reply By: Member - Boobook - Sunday, Feb 04, 2018 at 16:41
Completely bypass the wiring to that. A typical fridge will draw 5 - 6 amps. ( and an average of about 1 - 2 A)
Toyota have somehow managed to use wire thinner than the hair of an ant, and rate it at 10A ( 120W). There are 2 problems with the factory wiring.
1)The voltage drop at 5A will be too high and your fridge will cut out while the battery is still high.
2)It's probably wired to the accessory circuit and wont work when the ignition is off.
616662
Follow Up By: RMD - Sunday, Feb 04, 2018 at 19:51
Nearly all modern vehicle wiring is just enough to make it work but not to avoid voltage drop as Bookook has said.
Anything additional for accessories should be reliably supplied so as to ensure the performance of the appliance.
Although different situation, my old HJ61 Toyota had 10.8 v at the headlights when alt was 14v. After making a proper loom, as suggested for the fridge, my headlight ran at 13.8v. Use an Anderson plug and have one on the fridge too so a positive connection is maintained.
888139
Reply By: Genny - Sunday, Feb 04, 2018 at 17:55
Good to see Toyota copping some stick ..........
about the wiring on a Pajero! :) :) :)
616666
Follow Up By: RMD - Sunday, Feb 04, 2018 at 19:52
They all make to a PRICE.
888140
Follow Up By: Member - Boobook - Sunday, Feb 04, 2018 at 21:51
Ahh good point Genny. I was thinking it was a Prado for some reason.
888141
Reply By: Member - Mark (Tamworth NSW) - Sunday, Feb 04, 2018 at 18:15
Robert
Unless something has changed from the NP,NS and now 2014 NW Pajero that I have owned, it won't even run a Waeco 50A fridge when the engine is turned off (alternator isn't functioning)
The wiring resistance is just too high
From memory the standard rear fitting only works on ACC or when the engine is running, no power when the key is removed from the ignition.
So it will probably work when driving, forget it otherwise
If you want to run the fridge when the engine is turned off, you will need to run heavier gauge to the rear point.
Mark
616667
Reply By: HKB Electronics - Sunday, Feb 04, 2018 at 18:31
Personally I wouldn't run and reasonable size fridge from a factory power outlet as the wiring is very small and the quality of the outlet would be questionable.
My second concern would be if your using the factory outlets then you probably intend to run the fridge from the cranking battery which again is a worry.
Third point as pointed out above in some vehicles the power outlet aren't active with the ignition off. In some this can be overcome by linking out the relay that controls the circuit but your using the cranking battery and loosing any protection it had.
616668
Reply By: swampy - Sunday, Feb 04, 2018 at 19:50
hi
Fridge surge amp demand may cause volts to go low . Fridge may cut out . May happen a little or a lot but never at a convenient time .
A surging compressor has a shorter life !!
Low batt volt at compressor end happen even quicker due to the volt drop in cable.
Its best not to use starter battery for fridge supply .
The aux /ciggy plug rating might be10 amp but continuous will be a max of 5 amp or less .
second battery to fuse to low volt disconnect [set at 12 volts] to fridge
At least 6mm auto == 4.5sqmm wire size
616670
