Self inflating mattress
Submitted: Thursday, Mar 15, 2018 at 02:59
ThreadID: 136408 Views:5082 Replies:8 FollowUps:15
Looking to buy self inflating mattress for camping , i realise there are lots of previous threads on this but looking for up to date advice on what type, brand etc .
There is one advertised on tv which shows a vehicle driving all over it !! Any knowledge on these please ??
Reply By: Malcom M - Thursday, Mar 15, 2018 at 06:51
Maybe tell us what your intended use is?
We have a couple of Exped mats (a SimComfort 7.5 and a Mega Mat 7.5) that are rated down to -17C meaning you can put it on the snow and still stay toasty warm.
Really comfortable and bullet proof. We have hundreds of nights on each of them from the Vic High Country to Cape York in a tent..
Not cheap but great quality. The cheap crappy Chinese things roll up into a smaller space but we have had a lot of those die before buying something good.
AnswerID: 617561
Follow Up By: Member - Mark (Tamworth NSW) - Thursday, Mar 15, 2018 at 07:49
Malcolm
Ditto, don't waste your time on cheaper ones as they will develop leaks very quickly.
The original brand of SIMs is Thermarest, like Exped is not cheap but if you think you will want to use them for yars to come, well worth the extra $s. We also have a Black Wolf one which is cheaper then the previous brands which has stood the test of time.
I've seen good reviews for Sea to Summit brands. The Kathmandu brand ones we bought about 15 years ago were complete rubbish and the response from the shop I took them back to after failing on their first use was "what do you expect, they all leak".
You will get a good nights sleep out of quite thin (talking about 25-35mm expanded) good brand SIMs, you don't need 100mm thick ones.
FollowupID: 889272
Follow Up By: Michael H9 - Thursday, Mar 15, 2018 at 08:18
I'd like a 3/4 one that's a bit wider while we are at it. They are all quite narrow and my muscles don't fit....:-)
FollowupID: 889273
Follow Up By: Malcom M - Thursday, Mar 15, 2018 at 08:20
25-35mm doesn't do it for us. We like the much thicker ones as you can adjust the pressure to get your comfort level.
Thin ones have to be pumped up hard to keep your hips off the ground. We are too old for that nonsense :)
Our Kathmandus crapped out quickly as well.
FollowupID: 889274
Follow Up By: gbc - Thursday, Mar 15, 2018 at 09:36
Ladies close your ears - If you want a wider one, get the female fit SIM - don't ask ;)
'Much thicker' ones are nearly always unbonded meaning the external liner isn't bonded to the foam and you need to adjust air pressure more. I'd take a 35mm bonded over a 75mm unbonded every day.
For max comfort the newer fully inflatable insulated mats are lighter, smaller and apparently more comfortable again. Have a look at the likes of a thermarest neo air. I don't have one and am probably not likely to need one. Any lightweight camping I do these days is with my expedition hammock which beats laying on any mattress.
FollowupID: 889276
Follow Up By: Brian - Thursday, Mar 15, 2018 at 10:21
Thanks all , Malcom its for inside a black wolf tent . Are they double size ?
FollowupID: 889277
Follow Up By: Malcom M - Thursday, Mar 15, 2018 at 10:46
Brian,
Ours are singles but Exped do doubles as well.
Have a look here https://adventuregearonline.com.au/product-category/types/equipment/sleeping-mats/
FollowupID: 889279
Follow Up By: Brian - Thursday, Mar 15, 2018 at 11:06
The brand i was refering to that showed a vehicle driving over it was EUROBED ( i think )
FollowupID: 889281
Follow Up By: Malcom M - Thursday, Mar 15, 2018 at 11:49
Brian
Note that the Exped singles have a velcro strip running along the sides so you can stick two together.
Gives you control over the inflation of each half...
Those eurobed things are just a big bag of air. No insulation capability at all. Cheap and chearfull.
All depends on what sort of camping you intend to do and how long you intend to keep it...
FollowupID: 889282
Follow Up By: Genny - Thursday, Mar 15, 2018 at 21:50
We have a Eurobed as a spare for visitors, and I slept on it once. Sucks the warmth from your bones like there is no tomorrow!
Not really self inflating (the queen does have a 240V pump built in), and probably less than ideal for camping.
FollowupID: 889302
Follow Up By: Member - ACD 1 - Thursday, Mar 15, 2018 at 22:47
@Genny
Likewise with ours, although it is a queen size.
I put one of those velour (hotel type) blankets underneath the bottom fitted sheet. Stops the heat loss.
Anthony
FollowupID: 889308
Reply By: Member - Bigfish - Thursday, Mar 15, 2018 at 08:35
I have the Exped. Bought from Snowy,s. Best mattress I have used in 50+ years of camping!
AnswerID: 617562
Reply By: Rainman WA - Thursday, Mar 15, 2018 at 09:59
I've got the Exped Megamat 10. Inflates out to 10cm and deflates down to around 20cm when rolled up, and is the most comfortable mattress I've used for sleeping on the ground. The only problem is the price, from memory I paid close to $300 for it 4 or 5 years ago.
AnswerID: 617563
Follow Up By: Malcom M - Thursday, Mar 15, 2018 at 10:47
Yes, expensive but offset that against numerous Chinese failures and you come out ahead :)
FollowupID: 889280
Follow Up By: Member - Bigfish - Thursday, Mar 15, 2018 at 15:06
Got the same from Snowy,s when on special. $230 DELIVERED. 2 YEARS AGO....
FollowupID: 889288
Reply By: CSeaJay - Thursday, Mar 15, 2018 at 12:14
Had bad experiences with cheapie ones.
Then forked out for a Thermorest , that was 10 years ago and still sleeping comfortably on it
AnswerID: 617565
Reply By: bazz - Thursday, Mar 15, 2018 at 14:55
Just returned one to Anaconda ..130 $ it unbonded , buy Thrmarest Neo Air , forget the budget stuff .
AnswerID: 617567
Reply By: Mick O - Thursday, Mar 15, 2018 at 15:08
I’ve had a thermarest matteress (big boy size) for over 20 years. It’s been carted around the world and used in climates from – 35 to +47C and continues to give great service. It’s advantage is its size when rolled up. Still large but it is 2.0m long and 75 wide inflating to 4cm.
Being some 20 years older now and sporting a lot more war wounds, I use the ExPed Megamat and let me confirm what’s been said above. It is the most comfortable self inflater I’ve ever slept on. The only cons are its size (25cm x 900cm) when rolled up and its price of $300. Given what I know now, it’s $300 well spent. I’ve used this on my recent quad expeditions of up to a week in the wilds and after a hard day flogging it across god awful country, getting a comfortable nights sleep is a distinct advantage. With 10cm of loft means its well insulated and robust it handles my 120kg frame comfortably and at 900 wide, plenty of room to toss and turn.
It’s all been said above. If you have the room and you can afford the $, the Megamat is the only option.
Mick
AnswerID: 617568
Reply By: Member - Buzzo - Thursday, Mar 15, 2018 at 19:10
G'day. I'm interested in how long you guys have had your exped's? Mine hadn't been used much but delaminated on the ribs and had to be thrown out after 5-6 years.
AnswerID: 617571
Follow Up By: Malcom M - Friday, Mar 16, 2018 at 06:16
One of mine is older than that.
I know they had a bad batch about 5yrs ago with delaminating but my ones either side of that era have been fautless.
FollowupID: 889311
Reply By: Brian - Friday, Mar 16, 2018 at 00:38
Thanks everyone for your helpfull comments .Unfortunately there were really only 2 stores in Bunbury to choose from and no Exped or Thermarest in either store , even rang supposed agents of Thermarest in Midland Perth , they didnt have a double Thermarest so i opted out and bought a double Wanderer in Bunbury , lets hope it gives reasonable service
AnswerID: 617581
Follow Up By: Malcom M - Friday, Mar 16, 2018 at 06:19
No mail order out your way?
Snowies has free postage and AdventureGear usually has the cheapest price plus cheap post. Have bought one from each.
BCF thing right? Don't lose the receipt.
FollowupID: 889312
Follow Up By: Member - graeme W (WA) - Wednesday, Mar 21, 2018 at 23:03
Hi Brian, army surplus in Bunbury sell exped, we have two ,the best I have ever slept on. They will match price or better it.
FollowupID: 889528
